Nexus 3548 : vlan is not allowed on peer-link
Andrew Cormier
Hi, I had posted earlier but I think I have almost figured out the issue.. just not how to resolve it. I have two nexus switches connected together with PO5. Each nexus has a PO6 to connect to a single Cat3750 VLAN 46 on one of the switches is showing %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 46 on Interface port-channel6 are being suspended. (Reason: Vlan is not allowed on Peer-link) Oddly the other switch seems to ok with VLAN 46. I also see this show vpc consistency-parameters vpc 6 ... Local Remote. Allowed VLANs - 1,31,34,46,200,600-605 1,31,34,46,200,600-605 Local suspended VLANs - 46 - I just dont get it. Both switches are almost identical in their running configs. Any thoughts?
Glad to know it is working. Some times resting the vlan, interface or po interface does the job.
7 Replies 7
Reza Sharifi
Can you post the config from both switches including the VPC peer link config?
also config from the 3750.
well the funny thing about the nexus configs is that I compared them in notepad ++ and they are the same.
vrf context management
  ip route 0.0.0.0/0 10.31.0.9
vlan 1
vlan 31
  name VLAN0031-VOIP
vlan 34
  name vlan_nutanix
vlan 46
  name VLAN0046-MITEL
vlan 200
  name VLAN0200-ExchDAG
vlan 600
  name VLAN0600-VMOTION
vlan 601
  name VLAN0601-DMZ1
vlan 602
  name VLAN0602-DMZ2
vlan 603
  name VLAN0603-DMZ3
vlan 604
  name VLAN0604-DMZ4
vlan 605
  name VLAN0605-PNET
vpc domain 1
  role priority 110
  peer-keepalive destination 10.31.61.11 source 10.31.61.12
  auto-recovery
interface port-channel5
  switchport mode trunk
  spanning-tree port type network
  speed 10000
  vpc peer-link
interface port-channel6
  spanning-tree port type normal
  speed 1000
  vpc 6
interface port-channel11
  switchport trunk allowed vlan 1,31,34,46,200,600-605
  spanning-tree port type edge trunk
  speed 10000
  vpc 11
interface port-channel12
  speed 10000
  vpc 12
interface port-channel13
  speed 10000
  vpc 13
interface port-channel14
  speed 10000
  vpc 14
interface port-channel15
  speed 10000
  vpc 15
interface Ethernet1/1
  speed 1000
  channel-group 6 mode active
interface Ethernet1/2
  speed 1000
interface Ethernet1/3
  description Nutanix
  channel-group 11
interface Ethernet1/4
  description Nutanix
  channel-group 12
interface Ethernet1/5
  description Nutanix
  channel-group 13
interface Ethernet1/6
  description Nutanix
  channel-group 14
interface Ethernet1/7
  description Nutanix
  channel-group 15
interface Ethernet1/47
  channel-group 5 mode active
interface Ethernet1/48
3750 confing
interface Port-channel6
interface GigabitEthernet1/0/33
 description ch nexus1-1
interface GigabitEthernet1/0/34
 description ch nexus1-2
interface GigabitEthernet1/0/35
 description ch nexus2-1
interface GigabitEthernet1/0/36
 description ch nexus2-2
interface Vlan46
 ip address 172.17.16.1 255.255.255.0
The config looks good.
Can you try shut and no shut po6?
Also, does "sh int trunk" show all vlans being on vpc peer link (po5)?
Well sho int trunk does show all vlans being on po5 on both switches (vlan 1-4094)
On switch 2 it still shows Vlan 46 as being err disabled (see below)
Cant really do an shut/noshut on PO6 without a maintenance window :( I will see what I can do)
I did (desparately) try a status active and a no shut on vlan 46
Port          Vlans Err-disabled on Trunk
Eth1/1        46
Eth1/2        46
Po5           none
Po6           46
So I couldnt shut/noshut PO6 but I could do it to vlan 46. Guess what.. it worked.
Well here I am, almost 10 years later but on a 9372, same issue to the T.
Shut/no shut the vlan int on the one problem switch and it worked.
