Cisco 3850 Can not boot - System LED Flashing
DavidCopper
Hi, I'm having 2 Ciso 3850 running stack mode. Today I try to power on 2 switches and it can not boot, the system led flashing all the time.
I tried:
1. Power off 2 switches and remove stack cable
2. Power on 1 switches and hold MODE button to go to ROMMON, but the System led does not change status
Can some one help me please. Thank you.
8 Replies 8
balaji.bandi
Personally i believe you need to raise TAC case RMA if you have contract.
but you can try below method.
You can try download the image to USB and see if you can able to boo the device.
example :
switch: boot usbflash0:cat3k_caa-universalk9.16.09.03a.SPA.bin
follow below guide for more details :
https://community.cisco.com/t5/networking-knowledge-base/recovering-from-a-3850-boot-failure/ta-p/3136638
BB
Thank you. I will try
Leo Laohoo
The switch is dead.
Contact TAC and organize RMA.
sad to hear that
Why is that?
It is only "sad to hear that" if nobody wants to make an effort to RMA the switch even though every 3850 purchased comes with Enhanced Limited Lifetime Hardware Warranty.
We have never paid for maintenance to our fleet of 2960S, 3750E/3750X, 3850, 9300/9500 and APs because of LLHW/E-LLHW.
 I mean it's sad to hear that the switch is dead. I will try to RMA.
I try to check my switch SN on https://cway.cisco.com/sncheck/ and it shows like this. Will I be able to RMA?
Look at the right-hand box.  It says "Warranty COVERED".
