Cisco 3850 Dual Power Supply - One No Response
kevin.b.smith
Hey Guys,
I am getting multiple switches on my network showing "power supply failure" from Solarwinds.
I am running Cisco 3850s running v 03.02.03.SE cat3k_caa-universalk9 iOS, and they all have dual power supplies. When i do the sh env power, I get this output.
SWITCH1#sh env power
SW  PID                             Serial#     Status               Sys Pwr  PoE Pwr  Watts
1A  PWR-C1-715WAC       xxxx           OK                 Good     Good           715
1B  PWR-C1-715WAC       xxxx         No Response   Good     Good           715
SWITCH2#sh env power
When I physically go down to look at the switches, they have green lights, so they are receiving power, but I keep getting the PSU failure alerts.
Do you think it is an iOS issue, and should I upgrade? Or has anyone else seen this?
Reza Sharifi
Before you upgrade the IOS, I recommend you open a ticket with SolarWinds, as some versions of NPM have more bugs then others.
John Cui
I think below Bug could match with your issue.
"power supply B is not responding" reoccurring on Catalyst switches
https://tools.cisco.com/bugsearch/bug/CSCun41735/?reffering_site=dumpcr
And we can see workaround of this issue is HW workaround.
Jack
I do not have enough permissions to view this bug. Could you give me any details on how I can view this?
Hi Kevin,
Did you find a solution for your issue? We are facing the same problem, and we're not sure if the power supply is damaged.
