Cisco 3850 from IP-Services to IP-Base, How??
Beacon Bits
Hi guys,
I have Cisco WS-C3850-48P, verison 16.12.10a.
License Entitlement tag Count Status
C3850_48_Ipserv (C3850-48 IP Services)
At the moment, it is using IP Services. It has also added as smart licence.
I would like to convert this back to IP Base as we are not using IP Services features.
I do not see any command/option on the cli.
How can this be achieved?
B
5 Replies 5
M02@rt37
Hello @Beacon Bits
check your licence :
Activate ipbase: #license right-to-use activate ipbase (all) --all if you have a stack
Best regards
Cisco3850#license ?
smart Smart licensing
Cisco3850#license sm
Cisco3850#license smart ?
clear Clear
conversion Start or stop a license conversion
deregister deregister this device
export Get or return an export authorization key
factory Execute Smart Licensing Factory commands
register register token id
renew Smart License renew
send license smart send
There is no option for license right-to-use command.
@Beacon Bits
Cisco3850(config)#license boot level ipbasek9
wr and need a reboot yes.
Best regards
Beacon Bits
I have found the option to use different level of booting that allows the smart license feature.
Cisco3850(config)#license ?
boot license boot config commands
Cisco3850(config)#license boot ?
level which level to boot
Cisco3850(config)#license boot level ?
ipbasek9 License Level IPBASEK9
ipservicesk9 License Level IPSERVICESK9
lanbasek9 License Level LANBASEK9
Cisco3850(config)#license boot level lanbasek9 ?
addon select add-on to include DNA License
<cr> <cr>
I still not sure if it requires a reboot or not.
