Cisco 3850 Lost Connection When Using Interface Range Command To Remove Dot1x Commands
seanharvey15116
Good Morning,
Using the interface range to remove dot1x commands from Cisco 3850 switchport interfaces, we lost SSH connection to the switch. The interface range was Gi1/0/3 to Gi1/0/47. The router was connected to Gi1/0/48 on the switch. We are trying to determine why using the interface range commands to remove dot1x commands made the switch inaccessible. Could there a memory buffer that could cause the switch inaccessible? Has everyone experienced this same behavior with Cisco 3850?
9 Replies 9
Leo Laohoo
Our switches, running 16.9.5 and 16.12.4, crash when we APPLIED Dot1x into ranged ports.
our switch is on 16.09.04. Was there a cash file generated when your switch crash? Was there a bug ID for this issue?
s1-glsdoedpem#sh ver
Cisco IOS XE Software, Version 16.09.04
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.9.4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 22-Aug-19 17:33 by mcpre
TAC says "the fix is in 16.12.4".  Well, that was a major catastrophe because we walked straight into a major PoE bug that is found in the entire 16.12.X train (16.12.1 to 16.12.4).  The bug "bites" after 8 weeks.  If SMU is applied, the bug "bites" after 4 weeks.
I also created a new TAC Case yesterday because we have another stack, running 16.9.5, having a memory leak:
4-RP0 Critical  3977748  3874060 (97%)   103688 ( 3%)   4808000 (121%)
If this is the same bug as my previous TAC Case, the fix is meant to be in, you guessed it, 16.12.4.
So now, I have a major dilemma:  Regularly reboot stack with memory leak or upgrade to 16.12.4 and regularly reboot the stack every 4 to 8 weeks before the PoE bug bites.
Good Morning,
Did Cisco TAC provide you with a Bug ID?
The first memory leak was attributed to a brand-new Bug ID:  CSCvv66845
I am still waiting for the 2nd TAC Case to get analyzed.
TAC has confirmed that the 2nd TAC Case, memory leak on 3850 stack running 16.9.5, is due to the same bug, CSCvv66845
NOTE
  • From what I have observed, this bug gets triggered when the stack is configured for Dot1X.  We have several stacks running this same IOS-XE version but NOT on Dot1X and I do not see any signs of memory leak.
  • Workaround is reboot the stack every <35 weeks.
  • Permanent fix is to upgrade to 16.12.X and run the risk of hitting CSCvv28324, which, cannot be resolved even when SMU is applied.
Thank you for the information!
Thank you for the information.
Mark Elsen
                  - You may also want to check the logs when this happens.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
