SG350x vlan interface automatically changes to trunk on first connection.
Ik have 3 SG350x switches stacked with 6 Vlan's configured.
on first connection of a device to a port in a VLAN the switch automatically configures the interface to a trunk port instead of a access port.
This is not e wanted behaviour.
Which feature does this and how can i prevent it.
Thx !
5 Replies 5
balaji.bandi
we are not sure what port you referring, can you please post the screenshot to understand or refer below document can help you :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350x-series-stackable-managed-switches/smb5408-configure-stack-settings-on-an-sg350x-switch.html
BB
Before any PC has been connected to port 5 in the switch, this port is confugured as Access port:
After the connection of a pc to port 5, the Interface VLAN Mode is automatically set to Trunk.
Smart-port config detault enable - so disable.
BB
That was it !
Many thanks.
