Cisco 3850 Port-speed ?
Waheed Bahaduri
What is the default port-speed of Cisco CAT3850 switches ?  is it FastEthernet or Gigabit_Ethernet ?
because in the datasheet, in the ordering section it is writen only Ethernet not Gigabit_Ethernet:
WS-C3850-24T-S
Stackable 24 10/100/1000 Ethernet ports, with 350WAC power supply
1 RU, IP Base feature set
WS-C3850-12S-S
Stackable 12 SFP Ethernet ports, with 350WAC power supply
What that means,  please explain.
I want to order the 2 above part-numbers, but need its ports speed to be GE supported.  is it the right ones i have chosen?
6 Replies 6
Both the switches are GE supported.Below are the more details
WS-C3850-12S-S   ----> 12 gig 12 Small Form-Factor Pluggable (SFP)
WS-C3850-24T-S  --->  24 gig port , option network module support 4x1GE and 2X 10GE
WS-C3850-24T-S24350W, no PoE4 x 1 GE
2 x 10 GE
Yes
2 x 10 GE
Yes
WS-C3850-12S-S
WS-C3850-12S-S12 Small Form-Factor Pluggable (SFP)350W, no PoE4 x 1 GE
2 x 10 GE
Yes
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
VS.Suresh.
*Plz rate the usefull posts.
Hi Suresh
For  WS-C3850-24T-S  --->    if i dont order the (option network module support 4x1GE and 2X 10GE ) ,  still it has 24- Gigabit-ports supprted bydefault ?
Wbahaduri,
Yes you are correct.
Optional are upto customer if they want to use it or not. But if you buy the switch(WS-C3850-24T-S) you would get the 24 ports to be used by default.
Inayath
sorry it was not cleared for me, my question was if i order (WS-C3850-24T-S)  without ordering the network module 4x1GE and 2X 10GE.   then I will get 24-gigabit  port or not ?
Yes you would get.
You will be able to use 24-gigabit port.
Hello Wbahaduri,
By default you will get 24 gigabit port on the switch . Optional means you can order if you require and its not mandatory .
If want then order additional modules and get 4x 1GE and 2x 10 GE Extra ..
VS.Suresh.
