connecting 2, Nexus 5K to single Nexus 7K
Dragomir
I dont have dual 7K on the core layer. I only have one, but in the distribution layer I have 2 5ks,
how different would the config be without dual 7K?
Can I create single port channel from both 5Ks to the 7K?
what do I need to be aware of?
InayathUlla Sharieff
Based on your daigram you dont need to configure VPC. Simple etherchannel/Portchannel is required.
VPC is required when you are going to connecting the switch to two uplink different switches and want to form the  bundle.
To have simplicity I would create two Port-Channel for your setup.
1- Port E3/45 &E4/45 to be part of 1 Port-Channel.
2- Port E3/46 & E4/46 to be part of 2nd port-channel.
Inayath
