Cisco 3850 Recovery
waubie
I'm currently experiencing an issue where my 3850 is no longer booting with the IOS is goes directly to the switch: prompt.
When I do a DIR command it doesn't show the Flash: directory.
I tried to perform the Flash_Init with the Emergency-Install using usbflash0: with no luck.
It comes up with no such device for the Flash.
The USB is working I'm able to do a listing of the contents.
Is it possible that the IDE drive is corrupt?
Wayne
balaji.bandi
here is the guide to recovery from Switch: prompt
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html
make sure you formatted the USB  right format, try use differnet vendor USB if not working.
BB
The USB is working fine, and I went through the recovery procedure.
The problem is that I don't have any Flash: directory when I perform the DIR command at the SWITCH prompt
1. Boot from usbflash0: and after successful boot from usbflash0:
2. Format flash:
3. Copy the IOS XE what you looking to upgrade from usbflash0: to flash:,
4. change the "boot system switch all flash:version.bin.
5.reboot
BB
Raise a TAC Case and organize for an RMA.
