05-18-2016 06:46 AM - edited 03-08-2019 05:48 AM
Hello.
Could you tell whether the reflexive ACLs is gone in new Cisco 4451 Series of routers with IOS XE? It seems there aren't commands evaluate and reflect into ACL's config section anymore.
Thanks.
05-18-2016 07:19 AM
Yes, reflexive ACLs are not supported on IOS-XE for ISRs and ASRs, the option is to use ZBFW, see the link below:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_zbf/configuration/xe-16/sec-data-zbf-xe-16-book.html
Hope this helps.
Jose
10-09-2018 06:46 AM
Any alternative similar to Reflexive ALC which does NOT require Security license?
