05-28-2011 02:14 PM - edited 03-06-2019 05:15 PM
I have two cisco 4500 and I would do the same configuration as is done with the Cisco 6500, the vss. How it works in 4500? How do I make the redundancy / contingency with two switch 4500 to turn a virtual switch. In 6500 works well
Solved! Go to Solution.
05-28-2011 02:35 PM
It is supported, but you need Sup-7-E
have a look at this discussion for more info
https://supportforums.cisco.com/thread/2046271
Reza
05-28-2011 03:43 PM
yes, HSRP, VRRP
05-28-2011 02:35 PM
Reza
05-28-2011 02:38 PM
If I don´t have this module, there is another way? etherchannel + hsrp?
05-28-2011 03:43 PM
yes, HSRP, VRRP
05-29-2011 06:49 PM
Reza,
Its in the road map but not officially out yet. release notes for the Sup7E doesnt mention about VSS as yet.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-612364.html
So at the moment FHRP still seems to be the solution for 4k's
Kishore
05-28-2011 05:08 PM
Hello Daniel,
Cisco Catalyst 4500E series switches currently do not support virtual-switching technology. Currently this systems can be deployed in Standalone design and for redundancy you should leverage FHRP protocols in multilayer network. You may refer to following design guide for additional info:
thanks,
rahul.
