Cisco 4500X stopping tftp?
KGrev
Level 4
Level 4
I have been troubleshooting a TFTP blockage for days now.
Initially i was testing from a pc, sending across a 4500X then a 9500 then to another pc and the file created at the distant pc would be limited to 1kb somehow. I did the same test to a solarwinds server tftp and 1kb was the cutoff again. I changed my source to a pc on a vpn and it would still stop at 1kb.
After much troubleshooting it appears to be the 4500X that is causing the issue. I can send from a vpn pc to a pc directly connected to the 4500X and the file will be 1Kb. Also if the 4500X tries to send a flash: file from itself to the solarwinds tftp server or the directly connected pc it will be a 1kb file.
Is there a way i can debug this traffic or see this behavior happening? Thanks for any help!
11 Replies 11
   I would span the port for PC A and keep wireshark sniffing it for a while and than take a look on the logs. Not a guarantee but maybe the best way to actually see what can be happening.
I have wireshark on PC A, should i still span or just capture from there?
If possible maybe both. As the span is the network perspective and sometimes not the same information from the PC perspective.
Sorry it has taken me a long time to respond. I am having the worst time trying to set up ERSPAN. Cant get it to connect.
As a side note, i did a wireshark on the pc that is trying to send the tftp file and it shows the same four packets as the image earlier.
If I wireshark directly from pc A, I get these 4 packets. Its the same at the solarwinds server also.
Leo Laohoo
ip tftp block 8192
Is the above command present in any of the switches running IOS-XE?
If it is, please change the block size to 1468 and try again.
@Leo LaohooThanks for your response. I just tried your previous command before your update for 8192, no change. Then i changed to 1468, same result.
Did you check all IOS-XE switches?
@Leo LaohooThanks for your response. Currently my test is only using the 4500X so I only made adjustments on that device.
can you open the wiresharke SYN and SYN/ACK ? if Yes send me the photo of both packet
KGrev
Level 4
Level 4
In the end, faults in my own testing methodology were causing me issues and Mcafee was the culprit in the end.
