Cisco 4500x SUP Recovery Issues
Troy C.
Good Day
First off YES I know this stuff is old, I just manage and have no budget :0) With that said, I currently have multiple SUP cards on 3 different chasis's (SUP 6L+E, 7L+E) all having the same issues. They are up with no redundancy and I do have SUP 8's out there are not redundant so any help with this would be greatly appreciate for future failures.
When looking at the bootflash of each failed SUP, they've lost their IOS image completely. So, I've attempted many times to use the CF Card/Slot0: and TFTP to do a full recovery. It will begin the process of loading the SUP but then says there is no image in bootflash, (obviously or I'd load it).
I've read many forums etc. and have had no issues with TFTP communications etc. only that it doesn't do what it says it did for others. It currently does not go into a boot loop on its own, but if I load from TFTP or CF card it will loop 4-5 times then get stuck in rommon.I've disabled Autoboot a few times but it still goes to rommon looking for the file bootflash, I tried using the set command and playing with the config-register, the only options are 0x2100, 0x2101 and 0x2102 with the same result. I might also add, it completes is POST successfully every time.
When I unset boot and begin the recovery process and and tells me that the following is missing:
BOOT=bootflash:cat4500e-entservicesk9-mz.152-2.E8.bin,1;
No matter what the confreg says, or different outputs from my various attempts, it reverts to 0x2102 displays that the image is missing from bootflash.
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- bootflash:cat4500e-entservicesk9-mz.152-2.E8.bin
boot: can not load "bootflash:cat4500e-entservicesk9-mz.152-2.E8.bin"
I know.... and that's the issue, I just need to get it to load from TFTP to get it online and then copy the new image over to bootflash:. Not being able to edit the bootvar etc. without IOS is extremely annoying.
Has anyone else had this issue? Any advice would be great.
Thanks.
27 Replies 27
balaji.bandi
What chassis this SUP card installing and testing ?
Can you post complete boot logs which is failing.
Note : as you mentioned you went many documents i do not want to recommend at this stage what document refer (i would like to see complete boot logs and errors you getting from the time of switch on to booting with image)
BB
Troy C.
Chassis Type : WS-4507 R+E
Sup 6L-E 10GE (X2), 1000BaseX (SFP) WSX-X45-SU6L-E
As mentioned I've tried several options like confreg 0,1,2 etc but the output is the same so I'll post a couple.
rommon 5 >boot slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
Rommon reg: 0x00004380
Reset2Reg: 0x00008EFF
Darkside controller 0x0B46FB56..0x0B47DF08 original size:0x00012092##
Fortooine controller 0x0B5C73C8..0x0B72F93F original size:0x001C685D
diagsk5 version 5.0.2.3
prod: WS-X45-SUP6L-E part: 73-12088-05 serial: JAE1335HKHH
Power-on-self-test for Module 3: WS-X45-SUP6L-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Looopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
Switching Subsystem Memory ...
Packet Memory Test Results: Pass
Module 3 Passed
Rommon reg: 0x00000380
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.2(2)E8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 22-Jan-18 05:37 by prod_rel_team
VECTOR 0
* Welcome to Rom Monitor for WS-X45-SUP6L-E System *
* Copyright (c) 2003-2011 by Cisco Systems, Inc. *
* All rights reserved. *
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
Rom Monitor Program Version 12.2(44r)SG10
CPU Rev: 2.1, Board Rev: 8, Board Type: 103, CPLD Nexu Rev: 12
Chassis: WS-C4507R-E
Front Panel Phy is Bcm5482s
Got Mac Address: 00:25:84:1d:d0:1a
MAC Address : 00-25-84-1d-d0-1a
IP Address : 10.1.1.2
Netmask : 255.255.255.0
Gateway : 10.1.1.3
TftpServer : Not set.
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
The switch will automatically reboot now...
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
Autoboot cancelled......... please wait!!!
rommon 1 >set
set
PS1=rommon ! >
DiagMonitorAction=Normal
RommonVer=12.2(44r)SG10
RET_2_RTS=22:00:00 AST Wed Nov 4 2015
RET_2_RCALTS=
CV=
PV=
SV=
IS=
IpAddr=10.1.1.2
Netmask=255.255.255.0
Broadcast=10.1.1.255
Gateway=10.1.1.3
ConsecPostPassedCnt=1116
ConfigReg=0x2102
BootedFileName=bootflash:cat4500e-entservicesk9-mz.152-2.E8.bin
Here is my TFTP after unsetting BOOT and using 0x2101. Same result with 0x2100
rommon 7 >boot tftp://10.1.1.3/cat4500e-entservicesk9-mz.152-2.E8.bin
Tftp Session details are ....
Filename : /cat4500e-entservicesk9-mz.152-2.E8.bin
Loading from TftpServer: 10.1.1.3
Received data packet # 78255
Loaded 40066155 bytes successfully.
seeprom: Pass
Test Results: Pass
Test Results: Pass
Module 3 Passed
cisco Systems, Inc.
VECTOR 0
Updating FAT...
Gateway : 10.1.1.3
TftpServer : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
rommon 1 >
I can go back tomorrow, we just had a power outage so this was in my TeraTerm from before.
Troy C.
There's not a lot of helpful info in there. It was getting stuck using TFTP at diagsk5 version 5.0.2.3 a few times as well.
Yeah, nah.  It is not 0x2101 but still at 0x2101.
Nope.  This one still says 0x2102.
Leo Laohoo
unset BOOT
BOOT=slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
Hi Leo and thanks for the reply.
I've done that many times. It begins to load, refers to bootflash: where there is no IOS and reloads. It also says boot and bootldr can only be changed in IOS. I'm not sure why but it always comes back to the same thing, the original 0x2102 and looks for the file in bootflash.
Here is the output from it, it just repeats the process until I Control C:
rommon 9 >boot slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
Updating FAT...
 Gateway      : 10.1.1.3
rommon 1 > [interrupt]
rommon 1 >set
 PS1=rommon ! >
 RET_2_RCALTS=
 CV=
 PV=
 SV=
 IS=
 IpAddr=10.1.1.2
 Gateway=10.1.1.3
 TftpServer=10.1.1.3
 ConsecPostPassedCnt=1117
 ConfigReg=0x2101
 BootedFileName=slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
rommon 2 >
 Established physical link 100Mb Full Duplex
 Network layer connectivity may take a few seconds
rommon 3 >ping 10.1
 Invalid IP address: 10.1 . Ping Failed
rommon 4 >ping 10.1.1.3
 Host 10.1.1.3  is alive
rommon 5 >unset boot
rommon 6 >set
 PS1=rommon ! >
 RET_2_RCALTS=
 CV=
 PV=
 SV=
 IS=
 IpAddr=10.1.1.2
 Gateway=10.1.1.3
 TftpServer=10.1.1.3
 ConfigReg=0x2101
 seeprom: Pass
 Test Results: Pass
 Test Results: Pass
Module 3 Passed
Troy C.
I've just attempted it again, see below. Sometimes it hangs here for a bit but and picks up but now its frozen.....
rommon 6 >dir slot0:
File Size (Bytes) File Name
17258288 c2800nm-advsecurityk9-mz.123-11.T7.bin
1646 sdmconfig-2811.cfg
4052480 sdm.tar
812032 es.tar
1007616 common.tar
1038 home.shtml
113152 home.tar
511939 128MB.sdf
780 vlan.dat
40066155 cat4500e-entservicesk9-mz.152-2.E8.bin
Total space = 64016384 bytes, Available = 172032 bytes
rommon 7 >unset boot
unset: "boot" does not exist
rommon 8 >boot slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
Troy C.
After the failed slot0: boot I attempted the TFTP, it froze at VECTOR 0 (bolded secction below), went to boot loop and tried to resume booting from bootflash:
rommon 6 >boot tftp://10.1.1.3/cat4500e-entservicesk9-mz.152-2.E8.bin
seeprom: Pass
Test Results: Pass
Test Results: Pass
Module 3 Passed
cisco Systems, Inc.
VECTOR 0
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
Updating FAT...
Gateway : 10.1.1.3
rommon 1 >
rommon 1 >
rommon 1 >
This is the wrong syntax.  The "BOOT" keyword is very case sensitive.
How is the config-registry changed?  The command, in ROMMON, is different.  It should be "confreg 0x02101".
Troy C.
As you can see bolded below, it will not take capital letters, only small.
rommon 1 >unset BOOT
unset: "BOOT" does not exist
rommon 2 >dir slot0:
4052480 sdm.tar
812032 es.tar
1007616 common.tar
1038 home.shtml
113152 home.tar
511939 128MB.sdf
780 vlan.dat
rommon 3 >BOOT slot0:cat4500e-entservicesk9-mz.152-2.E8.bin
monitor: command "BOOT" not found
rommon 4 >unset boot
Can you post the complete output to the command:
1.  set
2.  dir flash:
3.  dir bootflash:
Troy C.
rommon 5 >dir flash:
flash: : Invalid device name
rommon 6 >dir bootflash:
1892208 cat4500-e-ios-promupgrade-122_44r_SG10
142917 config_backup-Dec-12-17-41-31.320-AST-73
142765 config_backup-May--6-02-16-18.377-ADT-1
142765 config_backup-May--7-02-16-22.003-ADT-2
142566 config_backup--May--7-01-27-43.831-ADT-0
142566 config_backup-May--8-09-06-19.458-ADT-1
142566 config_backup-May--9-09-06-23.250-ADT-2
142566 config_backup-May-10-09-06-26.967-ADT-3
142567 config_backup-May-12-00-32-12.069-ADT-1
142939 config_backup-May-23-10-14-20.747-ADT-1
142567 config_backup--May-10-16-53-34.307-ADT-0
142567 config_backup-May-13-00-32-15.959-ADT-2
142567 config_backup-May-14-00-32-19.695-ADT-3
142567 config_backup-May-20-17-09-29.874-ADT-6
142567 config_backup--May-21-03-28-06.407-ADT-0
142567 config_backup-May-16-17-09-14.266-ADT-2
142567 config_backup-May-17-17-09-18.106-ADT-3
142567 config_backup-May-18-17-09-21.941-ADT-4
142567 config_backup-May-19-17-09-25.924-ADT-5
142567 config_backup--May-22-02-35-32.951-ADT-0
142939 config_backup-May-24-10-14-31.448-ADT-2
142849 config_backup-Nov--3-11-09-22.380-ADT-18
142849 config_backup-Oct-11-19-55-40.983-ADT-140
142849 config_backup-Oct-12-19-55-51.906-ADT-141
142849 config_backup-Oct-13-19-56-03.042-ADT-142
142849 config_backup-Oct-14-19-56-14.130-ADT-143
142849 config_backup-Oct-15-19-56-25.217-ADT-144
142849 config_backup-Oct-30-11-08-36.565-ADT-14
142849 config_backup-Oct-31-11-08-48.142-ADT-15
142849 config_backup-Nov--1-11-08-59.717-ADT-16
142849 config_backup-Nov--2-11-09-11.267-ADT-17
142848 config_backup--Nov--3-15-04-38.787-ADT-0
142848 config_backup--Nov--3-19-12-10.155-ADT-0
142997 config_backup-Sep-26-22-02-20.060-ADT-692
142997 config_backup-Sep-27-22-02-31.607-ADT-693
142997 config_backup-Sep-23-22-01-45.642-ADT-689
142997 config_backup-Sep-24-22-01-57.130-ADT-690
142997 config_backup-Sep-25-22-02-08.537-ADT-691
142997 config_backup-Sep-28-22-02-46.523-ADT-694
142997 config_backup-Sep-29-22-02-51.095-ADT-695
142916 config_backup--Jun--4-21-46-04.439-ADT-0
142917 config_backup-Dec--8-17-40-46.713-AST-69
142917 config_backup-Dec--9-17-40-57.678-AST-70
142917 config_backup-Dec-10-17-41-09.023-AST-71
142917 config_backup-Dec-11-17-41-20.115-AST-72
142917 config_backup--Jun-11-23-29-00.999-ADT-0
142917 config_backup-Jun-13-07-18-48.215-ADT-1
142917 config_backup-Jun-14-07-18-52.382-ADT-2
142917 config_backup-Jun-15-07-19-04.443-ADT-3
143204 config_backup--Oct-11-03-25-02.360-ADT-0
143204 config_backup-Oct-12-11-14-26.528-ADT-1
143204 config_backup-Oct-13-11-14-37.466-ADT-2
143204 config_backup--Oct-17-11-40-41.020-ADT-0
143204 config_backup-Oct-31-16-30-47.497-ADT-45
143204 config_backup-Nov--1-16-30-51.883-ADT-46
143204 config_backup-Nov--2-16-30-56.308-ADT-47
143204 config_backup-Oct-29-16-30-38.673-ADT-43
143204 config_backup-Oct-30-16-30-43.072-ADT-44
142910 config_backup-Nov-17-15-32-15.077-AST-62
142910 config_backup-Nov-18-15-32-19.417-AST-63
142910 config_backup-Nov-19-15-32-23.791-AST-64
142910 config_backup-Nov-20-15-32-28.182-AST-65
142910 config_backup-Nov-21-15-32-34.510-AST-66
Total space = 128282624 bytes, Available = 114212864 bytes
rommon 7 > set
PS1=rommon ! >
RET_2_RCALTS=
CV=
PV=
SV=
IS=
IpAddr=10.1.1.2
Gateway=10.1.1.3
TftpServer=10.1.1.3
ConfigReg=0x2102
ConsecPostPassedCnt=1121
rommon 8 >
