Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 4503-E and 3 COM 7700 connectivity problem
Dawood Khan
i have 3 vlans, vlan1 , vlan 10 and vlan 20 with vlan interface for intervlan routing and vtp configrued on my 4503-E switch because i have also two stacked 3750 switch in the network. i connect cisco 4503 switch with 3com 7700 switch using trunk ports. now the problem is that from 3com  7700 switch host are able to ping all 3 vlans but from cisco 4503  vlan 10 and vlan 20 are not able to ping host connected to 3com 7700 switch.
Reza Sharifi
Can you post the config from the 4503 and 7700?
also, what device is doing the routing between vlans?
