VLAN on 3com 2952 and Cisco 3750
humberjet
HI,
Pls help.
I have setup both Vlans on 3com and cisco. but it seems they cant talk to each other.
ive setup both on trunking mode, what supposed to be the solution on this?
thank in advance
So, the 3com switch is layer-2 only and the 3750 is layer-2 and 3?
I am not familiar with 3com config, but it appears that you have only enabled vlan 1 on the trunk port connecting to the 3750.  Can you also add vlan 3 and test again?
Is the vlan interface on the 3750 in up and up mode?
sh ip int bri vlan3
is interface gi1/0/1 in up and up mode
sh ip int bri gi1/0/1
how about the 3com interfaces?
6 Replies 6
Reza Sharifi
What is the topology look like?
How are the switches connected?
Can you provide "sh run" from the 3750?
Topology is
Cisco 3750       connected to        3com
g1/0/1                   -----------          g1/0/1
I created VLAN 3 for each switch.
here is the SH RUN
Cisco 3750
ip routing
interface GigabitEthernet1/0/1
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
switchport access vlan 3
spanning-tree portfast
interface Vlan3
ip address 10.3.0.1 255.255.0.0
ip route 0.0.0.0 0.0.0.0 10.0.0.137
3com 2952 Baseline
vlan 1
vlan 3
ip route-static 0.0.0.0 0.0.0.0 10.0.0.2
port link-type trunk
port trunk permit vlan 1
stp edged-port enable
port access vlan 3
Did i miss something? thank pls help
sh ip int bri vlan3
yup they are all up.. same as 3com switch.
The 3com switch uses web gui, it seems by default vlan1 is enabled on int g1/0/1.. let me try if I could add to permit vlan 3..
@Reza..
nice one that do the trick..
i just put the
port trunk permit vlan 1 to 3
then i can ping vlans on 3750..
Glad to help, and thanks for the rating
Good Luck Mark
Reza
