Cisco 4506 switch in Err-disable mode
Shariq Riazi
    I have a Cisco 4506 switch and its 10 gig interface is in error disable mode.I tried Shut and no shut the port couple of times but it transits from up to down number of times and then to error-disable. Did anyone else encountered this issue before. kindly advise the solution for the same. thanks
Peter Paluch
Hi Shariq,
Can you post the output of the show interface status err-disable ? That output contains the reason for putting your port into err-disabled state.
Best regards,
Peter
Dear All,
Do we have a solution for the same as we are having the same problem.
