Cisco 4507R-E: Need help with config for vlans
mansoorms
I'm unable to pass the required vlans networks to my firewall I have different vlans configured for each floor of the building,All these floors have Nortel switches which are connected to the core switch thru fibre link.
I have a cisco 4507R-E core switch.please find the config for the core switch below n let me know what else has to be done in order to pass the vlans to my firewalls.
Current configuration : 18527 bytes
hostname HQ_Prim_Core_Swt
boot-start-marker
boot-end-marker
enable secret 5 $1$xj2Z$TmV9chRtQWCuXYMsCtBVW/
enable password 7 13521317135C0729
username admin password 7 011202095205465E74
username srca password 7 120D09121C0E1F417F7D1A7D65
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.1.10.1 10.1.10.20
ip dhcp excluded-address 10.1.11.1 10.1.11.20
ip dhcp excluded-address 10.1.12.1 10.1.12.20
ip dhcp excluded-address 10.1.13.1 10.1.13.20
ip dhcp excluded-address 10.1.14.1 10.1.14.20
ip dhcp excluded-address 10.1.15.1 10.1.15.20
ip dhcp excluded-address 10.1.16.1 10.1.16.20
ip dhcp excluded-address 10.1.17.1 10.1.17.20
ip dhcp excluded-address 10.1.18.1 10.1.18.20
ip dhcp excluded-address 10.1.11.241 10.1.11.254
ip dhcp excluded-address 10.1.10.241 10.1.10.254
ip dhcp excluded-address 10.1.12.241 10.1.12.254
ip dhcp excluded-address 10.1.13.241 10.1.13.254
ip dhcp excluded-address 10.1.14.241 10.1.14.254
ip dhcp excluded-address 10.1.15.241 10.1.15.254
ip dhcp excluded-address 10.1.16.241 10.1.16.254
ip dhcp excluded-address 10.1.17.241 10.1.17.254
ip dhcp excluded-address 10.1.18.241 10.1.18.254
ip dhcp excluded-address 192.168.0.1 192.168.0.40
ip dhcp pool VLAN1
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.136
   dns-server 192.168.0.1 192.168.0.6
   netbios-name-server 192.168.0.1 192.168.0.6
   netbios-node-type h-node
ip dhcp-server 192.168.0.136
vtp mode transparent
cluster run
spanning-tree mode pvst
redundancy
mode sso
vlan internal allocation policy ascending
vlan 10
name Ground_Floor
vlan 11
name First_Floor
vlan 12
name Second_Floor
vlan 13
name Third_Floor
vlan 14
name Fourth_Floor
vlan 15
name Fifth_Floor
vlan 16
name Sixth_Floor
vlan 17
name Seventh_Floor
vlan 18
name Eighth_Floor
vlan 19
name Management
vlan 20
name Servers
vlan 21
name IP-Cameras
vlan 22
name Src_Voice
vlan 23
name Src_Vsat
vlan 30
vlan 31
name cloud
vlan 121
class-map match-all YOU
class-map match-all httpurl
interface GigabitEthernet5/9
switchport access vlan 16
switchport mode access
interface GigabitEthernet5/43
interface Vlan10
ip address 10.1.10.251 255.255.255.0
ip helper-address 10.1.20.101
ip helper-address 10.1.20.102
standby 10 ip 10.1.10.250
standby 10 preempt
interface Vlan11
ip address 10.1.11.251 255.255.255.0
standby 11 ip 10.1.11.250
standby 11 preempt
interface Vlan12
ip address 10.1.12.251 255.255.255.0
standby 12 ip 10.1.12.250
standby 12 preempt
interface Vlan13
ip address 10.1.13.251 255.255.255.0
standby 13 ip 10.1.13.250
standby 13 preempt
interface Vlan14
ip address 10.1.14.251 255.255.255.0
standby 14 ip 10.1.14.250
standby 14 preempt
interface Vlan15
ip address 10.1.15.251 255.255.255.0
standby 15 ip 10.1.15.250
standby 15 preempt
interface Vlan16
ip address 10.1.16.251 255.255.255.0
standby 15 preempt
standby 16 ip 10.1.16.250
standby 16 preempt
interface Vlan17
ip address 10.1.17.251 255.255.255.0
standby 17 ip 10.1.17.250
standby 17 preempt
interface Vlan18
ip address 10.1.18.251 255.255.255.0
standby 18 ip 10.1.18.250
standby 18 preempt
interface Vlan19
ip address 10.1.19.251 255.255.255.0
standby 19 ip 10.1.19.250
standby 19 preempt
interface Vlan20
ip address 10.1.20.251 255.255.255.0
standby 20 ip 10.1.20.250
standby 20 preempt
interface Vlan21
ip address 10.1.21.251 255.255.255.0
standby 21 ip 10.1.21.250
standby 21 preempt
interface Vlan22
ip address 10.1.22.251 255.255.255.0
standby 22 ip 10.1.22.250
standby 22 preempt
interface Vlan23
ip address 10.1.23.251 255.255.255.0
shutdown
standby 23 ip 10.1.23.250
standby 23 preempt
interface Vlan30
ip address 192.168.30.13 255.255.255.0
standby 30 ip 192.168.30.12
standby 30 preempt
interface Vlan31
ip address 10.101.1.53 255.255.255.0
interface Vlan121
ip address 192.168.168.251 255.255.255.0
shutdown
ip route profile
ip route 0.0.0.0 0.0.0.0 192.168.0.9
ip route 10.1.0.0 255.255.255.252 192.168.0.9
ip route 10.36.0.0 255.255.0.0 192.168.0.9
ip route 10.66.4.88 255.255.255.252 10.101.1.51
ip route 10.200.7.156 255.255.255.252 10.101.1.51
ip route 10.201.20.0 255.255.255.0 10.20.6.6
ip route 172.16.0.0 255.255.0.0 192.168.0.9
ip route 192.168.99.0 255.255.255.0 192.168.0.9
ip http server
ip http secure-server
route-map Operations permit 10
match ip address 30
set interface GigabitEthernet2/3
Kinly help/suggest.
5 Replies 5
Giuseppe Larosa
Hello Mansoor,
you are using static routing so there is nothing to pass to the firewall devices.
Have you configured appropriate static routes on the firewall devices for the 10.1.X.0 networks using the multilayer switch as IPv4 next-hop?
that is the return path?
Are the IP next-hops used in your static routes adjacent ( out of connected L3 interfaces)?
I see in the next-hops
192.168.0.9 ?
10.20.6.6 ?
10.101.1.51 ---> ok  out of SVI vlan 31
Hope to help
Giuseppe
Hi Larosa,
Thanx for response.
This is the first time i'm working with L3 switch.n the routes were already configured by the previous engineer.
I've  been assigned the task to allow the vlans10-18 from this switch to the  ASA 5510 firewall so that the users can access internet via ASA.
Can  u please show me how to allow the networks from 10.1.0.0 to  firewall.Also these networks are clasified as vlans10 to 18 as seen in  the config.
The ASA has following interfaces:
E0/0-xx.xxx.167.130/128
E0/1-shut
E0/2-10.1.16.75/24 (This is where the switch is connected)
M0/0- Management interface.
The ASA ip is 192.168.0.7.
If u need anything else please tell.
Kindly help me in configuring as this is critical.
Thanx.
Hi ,
I'm really sorry for not mentioning this fact from the  begining.Act all the users are accessing the internet thru Juniper i.e,  192.168.0.9 . Thats the reason u r seeing the default route in the  config of switch.
The requirement states that this connection via  ASA should be a backup one. Is it possible to configure that on Cisco  4507 R-E switch.
If i'm doing anything as u mentioned above the users will not able to access internet .
So kindly suggest me how to go.
Hi ,
I was able to access the internet on 6th floor only.
Other  users on other floors still unable to access the internet .
Kindly suggest me what else has to be one.
Hi Mansoor,
Have you checked your firewall?
Are you sure that it has nat for these networks?
Have you checked the access rules on your firewall?
If you are not sure please send a copy of firewall configuration.
