Cisco 4507R-E secondary SUP card is in disable state
k_bhavsar
Hi All,
I have one cisco 4507R-E switch with SUP 6-E. When I power UP switch. switch is boot with primary sup. Secondary module shown as "Disabled".
How can i enable secondary module?
Reza Sharifi
Have a look at this doc on how to make the sups redundant
You need to have the same exact IOS and license in both sups.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/RPR.html#wp1125437
