cisco 4948 configuration problem problem (Kindly provide CLI configuration
shouchemahendra
Having two cisco 4948 switch ,Want to uplink with two Links one with Ethernet port 10.XX n/W and other Fiber Uplink with 97.XX N/w also requirement is such that 1 to 16 port work with 10.XX N/w and 17 to 42 with 97.XX n/w and 43,44 port use for trunking with other switch with same configuration.Also require to Define VRRP for above both links with one VIP.
Edison Ortiz
#config t
(config)#vlan 10,97
(config)#exit
#config t
(config)# interface rang 1-16
(config)# switchport host
(config)# switchport access vlan 10
(config)# interface ran 17-42
(config)# switchport access vlan 97
(config)# interface rang 43-44
(config)# switchport trunk encap dot1q
(config)# switchport mode trunk
_________
Switch 1 VRRP
(config)# interface vlan 10
(config)# ip add 10.x.x.10
(config)# vrrp 10 ip 10.x.x.1
(config)# vrrp 10 priority 105
(config)# vrrp 10 preempt
(config)# interface vlan 97
(config)# ip add 97.x.x.10
(config)# vrrp 97 ip 97.x.x.1
(config)# vrrp 97 priority 105
(config)# vrrp 97 preempt
Switch 2 VRRP
(config)# ip add 10.x.x.20
(config)# ip add 97.x.x.20
HTH,
__
Edison.
