Cisco 4948 switches excessive drops
balla-zoltan
We have some issues with our 4948 switches namely there are a lot of drops on interfaces. Here is an example:
GigabitEthernet1/19 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 001b.d417.a792 (bia 001b.d417.a792)
  Description: USPHL0ESX18 RSA
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 6d17h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 17577272
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 23000 bits/sec, 33 packets/sec
     3083 packets input, 202707 bytes, 0 no buffer
     Received 299 broadcasts (0 multicasts)
     86584193 packets output, 52059988888 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Here is the interface configuration:
interface GigabitEthernet1/19
description USPHL0ESX18 RSA
switchport access vlan 120
speed 100
duplex full
spanning-tree portfast
The drops happen in a burst. The case was opened with TAC, but it looks like we have a run around.
6 Replies 6
Fabienne Stephanoff
Did you capture a sniffer trace of this interface while the drops were occurring? This looks like oversubscription. A capture would tell you for sure using the wireshark I/O graph feature.
Is qos enabled?
Cheers,
Fabienne
LAN-Switching TAC
Thank you  for your esponse. We have no empty ports o use wireshark. The interesting part is that there is only one device plugged into the port. It is the RSA card for that server is only for management, so, in theory, should not have a lot of traffic. QoS is not enabled on the port.
glen.grant
How is the far end port configured?  Seeing you hardcoded the 4948 port the far end would have to be hardcoded also otherwise the far end will default to 100/half duplex .  Output drops usuaully means the far end cannot handle the traffic fast enough .
Thank you for your response. The interface on the server is set to 100/full, just like the switch port. The interface does not have a lot of traffic because the RSA card is only for server management.
jkukorica
Szia!
Jutottál valamire az esetedben? Nekünk is van 4948-as és növekvő output drop, amit semmi sem indokol.
gigabitethernet 1/41
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  1000BaseX (SFP) Supervisor             WS-C4948
M MAC addresses                    Hw  Fw           Sw               Status
1 001f.ca75.72c0 to 001f.ca75.72ef 1.5 12.2(31r)SGA 12.2(54)SG1      Ok
Rövid idővel nullázás után !
* GigabitEthernet1/41      0     0    0 457632 67000    4 92921000  14218    0
* GigabitEthernet1/42      0     0    0     0 90135000  9246 13000    7    0
* GigabitEthernet1/43      0     0    0     0 1568000  786 53448000  8173    0
* GigabitEthernet1/44      0     0    0     0 1186000  315 60776000  9244    0
* GigabitEthernet1/45      0     0    0     0 4807000  1667 62027000  8756    0
* GigabitEthernet1/46      0     0    0     0 4144000  1733 58523000  8508    0
* GigabitEthernet1/47      0     0    0     0     0    0     0    0    0
Köszi!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If drops happen in a burst, then you might be experiencing traffic bandwidth bursts.  If so, drops can happen.
Can't run port at gig?  If not, next alternate would be increase buffer resources.
