Cisco 5506X Firepower Missing Access Control Add Icon
charlesjparker
I have updated to the following versions and when I go to the Access Control Policy editor, the screen goes to the default policy instead of stopping and allowing me to add/create a new Access Control policy.
Cisco Adaptive Security Appliance Software Version 9.8(2)20
Firepower Extensible Operating System Version 2.2(2.63)
Device Manager Version 7.9(1)151
So, I'm pretty much stuck here.  Any suggestions would be appreciated.
Following is the ASDM Java console logs:
______
Using JRE version 1.8.0_161 Java HotSpot(TM) 64-Bit Server VM
User home directory = /Users/
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
q: hide console
s: dump system properties
Application Logging Started at Wed Feb 21 17:36:55 EST 2018
Local Launcher Version = 1.8.0
Local Launcher Version Display = 1.8(0)
OK button clicked
Trying for ASDM Version file; url = https://192.168.1.1/admin/
Server Version = 7.9(1)151
Server Launcher Version = 1.8.0, size = 774656 bytes
Launcher version checking is successful.
invoking SGZ Loader..
Cache location = /Users/charlesjparker/.asdm/cache
2018-02-21 17:37:10,188 [ERROR] CLI-PASSTHROUGH-DEBUG Inside doInitialProcessing:
0 [SGZ Loader: launchSgzApplet] ERROR com.cisco.pdm.headless.startup - CLI-PASSTHROUGH-DEBUG Inside doInitialProcessing:
2018-02-21 17:37:10,206 [ERROR] CLI-PASSTHROUGH-DEBUG Inside doInitialProcessing messenger: clm@2aafcac6
18 [SGZ Loader: launchSgzApplet] ERROR com.cisco.pdm.headless.startup - CLI-PASSTHROUGH-DEBUG Inside doInitialProcessing messenger: clm@2aafcac6
com.jidesoft.plaf.LookAndFeelFactory not loaded.
Feb 21, 2018 10:37:35 PM ah a
INFO: Same version found on client. Continuing without downloading
Checking JxBrowser license jar:file:/Users/charlesjparker/.asdm/jxbrowser/runtime.jar!/META-INF/teamdev.licenses:
-- Product name: JxBrowser
-- Licensed version: 4.x
-- Licensed to:
-- License type: Runtime
-- Generation date: Mar 6, 2014
-- Expiration date: NEVER
-- License info: Not for development
-- Current date: Feb 21, 2018
JxBrowser license valid.
10:37:41 INFO: OS name: Mac OS X
10:37:41 INFO: JRE version: 1.8 32-bit
10:37:41 INFO: JxBrowser version: 4.9.5
10:37:41 INFO: Starting IPC...
10:37:41 INFO: Starting IPC Server...
10:37:41 INFO: Starting IPC Process...
10:37:41 INFO: Start Chromium process...
10:37:41 INFO: Command line: /var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/jxbrowser.app/Contents/MacOS/jxbrowser 1101 4277 --remote-debugging-port=9222 --ignore-certificate-errors
10:37:41 INFO: [0221/173741:INFO:main-delegate.cpp(48)] Frameworks path: /private/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/jxbrowser.app/Contents/Frameworks
10:37:41 INFO: [warn] kq_init: detected broken kqueue; not using.: Undefined error: 0
10:37:42 INFO: [warn] kq_init: detected broken kqueue; not using.: Undefined error: 0
10:37:42 INFO: READ: OnHelloMessage{type=OnHelloMessage, uid=1, message='cid:0,type:Main'}, null
10:37:42 INFO: Channel is accepted: SocketChannel{cid=0, bid=-1, type=Main}
10:37:42 INFO: IPC is started.
10:37:42 INFO: WRITE: CreateBrowserMessage{type=CreateBrowser, uid=0, channelId=0, contextId=-1, cacheDir='/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/data/Cache', memoryDir='/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/data/Memory', dataDir='/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/data', currentLocale='en-us', proxyType=-1, proxyRules='null', proxyBypassRules='null', proxyAutoConfigURL='null'}, SocketInfo{channelId=0, browserId=-1, channelType=Main}
10:37:42 INFO: [0221/173742:INFO:main-delegate.cpp(56)] Frameworks path: /private/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/jxbrowser.app/Contents/Frameworks
10:37:42 INFO: READ: OnHelloMessage{type=OnHelloMessage, uid=2, message='cid:0,bid:0,type:Browser'}, null
10:37:42 INFO: Channel is accepted: SocketChannel{cid=0, bid=0, type=Browser}
10:37:42 INFO: Channel is connected: SocketChannel{cid=0, bid=0, type=Browser}
10:37:42 INFO: WRITE: SetNetworkDelegateConfigMessage{type=SetNetworkDelegateConfig, uid=1, browserContextId=-1, onBeforeURLRequestDisabled=true, onBeforeSendHeadersDisabled=true, onSendHeadersDisabled=true, onHeadersReceivedDisabled=true, onBeforeRedirectDisabled=true, onResponseStartedDisabled=true, onCompletedDisabled=true, onPACScriptErrorDisabled=false, onAuthRequiredDisabled=false}, SocketInfo{channelId=0, browserId=-1, channelType=Main}
10:37:42 INFO: WRITE: LoadURLMessage{type=LoadURL, uid=2, url='about:blank', frameId=-1, extraHeaders='null', postData=null}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:43 INFO: READ: com.teamdev.jxbrowser.chromium.internal.ipc.message.OnRenderViewCreatedMessage@106a30d2, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:43 INFO: [0221/173743:INFO:main-delegate.cpp(56)] Frameworks path: /private/var/folders/9f/5y1w95l568j7bvvbn7860pzc0000gn/T/jxbrowser-chromium-39.0.2171.52.4.9.5/jxbrowser.app/Contents/Frameworks
10:37:43 INFO: [warn] kq_init: detected broken kqueue; not using.: Undefined error: 0
10:37:43 INFO: [0221/173743:ERROR:renderer_main.cc(207)] Running without renderer sandbox
10:37:43 INFO: READ: OnHelloMessage{type=OnHelloMessage, uid=1, message='cid:0,bid:0,type:Render'}, null
10:37:43 INFO: Channel is accepted: SocketChannel{cid=0, bid=0, type=Render}
10:37:43 INFO: Channel is connected: SocketChannel{cid=0, bid=0, type=Render}
10:37:43 INFO: RenderProcess has been created for channel: SocketChannel{cid=0, bid=0, type=Render}
10:37:43 INFO: READ: OnHandleLoadMessage{type=OnHandleLoadMessage, uid=2, url='about:blank', loadType=5, loadPpolicy=2, isBackForward=false, isRedirect=false, cancel=false}, SocketInfo{channelId=0, browserId=0, channelType=Render}
10:37:43 INFO: WRITE: OnHandleLoadMessage{type=OnHandleLoadMessage, uid=2, url='about:blank', loadType=5, loadPpolicy=2, isBackForward=false, isRedirect=false, cancel=false}, SocketInfo{channelId=0, browserId=0, channelType=Render}
10:37:43 INFO: READ: OnDidStartProvisionalLoadForFrameMessage{type=OnDidStartProvisionalLoadForFrame, uid=4, frameId=1, parentFrameId=-1, isMainFrame=true, validatedURL='about:blank', isErrorPage=false}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:44 INFO: READ: OnDidCommitProvisionalLoadForFrameMessage{type=OnDidCommitProvisionalLoadForFrame, uid=5, frameId=1, isMainFrame=true, transitionType=1, url='about:blank'}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:44 INFO: READ: OnStatusChangeMessage{type=OnStatusChangeMessage, uid=6, url=''}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:44 INFO: READ: OnDocumentLoadedInFrameMessage{type=OnDocumentLoadedInFrame, uid=7, frameId=1}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:44 INFO: READ: OnDidFinishLoadMessage{type=OnDidFinishLoad, uid=8, frameId=1, isMainFrame=true, validatedURL='about:blank'}, SocketInfo{channelId=0, browserId=0, channelType=Browser}
10:37:44 INFO: WRITE: SetNetworkDelegateConfigMessage{type=SetNetworkDelegateConfig, uid=3, browserContextId=-1, onBeforeURLRequestDisabled=false, onBeforeSendHeadersDisabled=false, onSendHeadersDisabled=false, onHeadersReceivedDisabled=false, onBeforeRedirectDisabled=false, onResponseStartedDisabled=false, onCompletedDisabled=false, onPACScriptErrorDisabled=false, onAuthRequiredDisabled=false}, SocketInfo{channelId=0, browserId=-1, channelType=Main}
Feb 21, 2018 10:37:44 PM ah a
INFO: Remote Debug Url:http://localhost:9222/devtools/devtools.html?ws=localhost:9222/devtools/page/07FD1AE8-1696-4508-86A1-ECEC15DB8244
IO Exception occurs while reading the dap file. java.io.FileNotFoundException: https://192.168.1.1/admin/flash/dap.xml
No CSD version
Feb 21, 2018 10:44:41 PM af$5 onStartLoadingFrame
INFO: Loading ... https://192.168.1.2/ddd/#FirewallPolicyEditor;uuid=c78e66bc-cb57-43fe-bcbf-96b79b3475b3
Feb 21, 2018 10:44:44 PM af$3 onTitleChange
INFO: Title = ASA5506 6.2.0.4 Build 85 (Sourcefire3D) - admin
2018-02-21 17:44:44,635 [ERROR] Progress indicator could not be displayed.
454447 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
2018-02-21 17:44:45,653 [ERROR] Progress indicator could not be displayed.
455465 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
Feb 21, 2018 10:45:10 PM af$5 onStartLoadingFrame
2018-02-21 17:45:12,365 [ERROR] Progress indicator could not be displayed.
482177 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
2018-02-21 17:45:13,369 [ERROR] Progress indicator could not be displayed.
483181 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
Feb 21, 2018 10:48:45 PM af$5 onStartLoadingFrame
2018-02-21 17:48:47,563 [ERROR] Progress indicator could not be displayed.
697375 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
2018-02-21 17:48:48,567 [ERROR] Progress indicator could not be displayed.
698379 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
Feb 21, 2018 10:49:11 PM af$5 onStartLoadingFrame
2018-02-21 17:49:13,750 [ERROR] Progress indicator could not be displayed.
723562 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
2018-02-21 17:49:14,752 [ERROR] Progress indicator could not be displayed.
724564 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
Feb 21, 2018 10:51:39 PM af$5 onStartLoadingFrame
2018-02-21 17:51:41,129 [ERROR] Progress indicator could not be displayed.
870941 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
2018-02-21 17:51:42,156 [ERROR] Progress indicator could not be displayed.
871968 [Browser Events Thread] ERROR com.cisco.dmcommon.util.DMCommonEnv - Progress indicator could not be displayed.
0 Replies 0
