Layer 3 Port-channel with subinterfaces
paranengmoose
Hi I am trying to figure out how to configure Layer 3 port-channel with subinterfaces.
This is my topology.
Two physical interfaces will be bundled into a single port-channel.
My CSR will act as a "Router On A Stick".
All interfaces on the switch are trunk port, allowing all vlans.
A ping from CSR to IOSv1 is currently not working.
Please take a look at my configuration.
--------CSR--------
interface port-channel 1
   no ip address
interface port-channel 1.101
   encapsulation dot1q 101
   ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet 2
   no ip address
   channel-group 1
interface GigabitEthernet 3
   no ip address
   channel-group 1
--------Switch--------
vlan 101
   name Test
interface GigabitEthernet 0/1
   switch trunk encapsulation dot1q
   switch mode trunk
interface GigabitEthernet 0/2
   switch mode trunk
interface GigabitEthernet 0/3
   switch mode trunk
--------IOSv-1--------
    ip address 1.1.1.2 255.255.255.0
Is there anything I am missing?
I appreciate your help in advance.
10 Replies 10
Reza Sharifi
Where is the Portchannel configuration for the switch?
Thanks for the reply.
There is no Port-channel configuration for the switch, because the port-channel on the router is only used for the failover purpose.
brselzer
I would think you would want to put the switch interfaces into a port-channel or you are going to potentially see mac flaps. However, I think it would still work.
I think your problem is that the IOS device is not tagging traffic so it is coming into the switch untagged. There is nothing telling it to put the traffic into vlan 101.
On the port connected to iosv-1, set it to either an access port in vlan 101 (switchport mode access and switchport access vlan 101) or change the native vlan to 101 (switch trunk native vlan 101)
Hope this helps!
-Bradley Selzer
CCIE# 60833
Hi Bradley,
Thank you very much for the detailed guide.
However, I also tried putting the port connected to iosv-1 into "switchport access vlan 101" and "switchport mode access", but got the same result.
I also created an "interface vlan 101" on the switch with IP address of 1.1.1.3/24, and tested the ping between each device. As a result, the ping between the switch(1.1.1.3) and IOSv-1(1.1.1.2) worked, but the ping between the switch(1.1.1.3) and CSR(1.1.1.1) didn't.
I think what you mentioned is true when it's applied to the CSR. The traffic from the CSR is not being tagged with vlan information. When I replaced the command "encapsulation dot1q 101" with "encapsulation dot1q 101 native", then the ping from CSR to the IOSv-1 worked.
How can I ensure the traffic from the port-channel subinterface gets tagged with vlan?
I appreciate your help, Bradley.
Can you repaste your configurations for the switch and CSR? You can leave out the IOS device since we know that is not the issue. Can you also gather the outputs of show spanning-tree from the switch?
Thanks!
-Bradley Selzer
CCIE# 60833
Thanks Bradley.
Please find them below.
-----------------------CSR------------------------------
interface Port-channel1
 no ip address
 negotiation auto
interface Port-channel1.101
 encapsulation dot1Q 101
interface GigabitEthernet2
 no ip address
 negotiation auto
 channel-group 1
interface GigabitEthernet3
 no ip address
 negotiation auto
 channel-group 1
---------------------Switch---------------------------
interface GigabitEthernet0/1
 negotiation auto
interface GigabitEthernet0/2
 negotiation auto
interface GigabitEthernet0/3
 media-type rj45
 negotiation auto
interface Vlan101
 ip address 1.1.1.3 255.255.255.0
----------------------Show spanning-tree------------------------
Switch#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     5e00.0001.0000
             Cost        4
             Port        1 (GigabitEthernet0/0)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     5e00.4000.0000
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/0               Root FWD 4         128.1    P2p
Gi0/1               Desg FWD 4         128.2    P2p
Gi0/2               Desg FWD 4         128.3    P2p
VLAN0101
  Root ID    Priority    32869
             This bridge is the root
  Bridge ID  Priority    32869  (priority 32768 sys-id-ext 101)
             Aging Time  300 sec
Gi0/3               Desg FWD 4         128.4    P2p
I have it now. You haven't actually made the interface trunks. The command "switchport trunk encapsulation dot1q" just sets the encapsulation IF the interface is a trunk. However, if you were to run "show run int gig0/1 switchport" the operational mode would be access in vlan 1.
You need to add "Switchport mode trunk" as well to Gig0/1 and Gig0/2 and remove the native KW from the port-channel on the CSR.
Hope that helps!
-Bradley Selzer
CCIE# 60833
Hi Bradley,
I simply forgot to include there.
But in the actual config, there was "switchport mode trunk" command under the interfaces on the switch. Also, the keyword "native" was not included in the port-channel configuration.
Thank you
There is something wrong because vlan 101 is not forwarding on Gig0/1 and Gig0/2. Is vtp enabled? Can you send over "show vtp status", "show int trunk", "show int gig0/1 switchport", and "show int gig0/1 pruning". Thanks!
-Bradley Selzer
CCIE# 60833
---------show vtp status---------
Switch#show vtp status
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : 5e00.4000.8000
Configuration last modified by 0.0.0.0 at 2-16-18 19:37:48
Local updater ID is 1.1.1.3 on interface Vl101 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 6
Configuration Revision            : 1
MD5 digest                        : 0x8B 0x7A 0x5D 0xE8 0xE6 0xD4 0x60 0x78
                                    0xD2 0xA3 0x6E 0x3C 0xFB 0x25 0x5F 0xB2
----------------show int trunk--------------
Switch# show interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q trunking 1
Gi0/2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/1 1-4094
Gi0/2 1-4094
Port Vlans allowed and active in management domain
Gi0/1 1,101
Gi0/2 1,101
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1,101
Gi0/2 1,101
-------------------show int gig0/1 switchport------------------
Switch#show interfaces gigabitEthernet 0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
--------------------show int gig0/1 pruning---------------------
Switch#show interfaces gigabitEthernet 0/1 pruning
Pruning not currently enabled in this device's VTP administrative domain.
Hi Bradley,
I really appreciate your help.
Is it possible to have a webex session with you?
I may be asking for too much, so please let me know if you don't want to.
I can send you a webex session.
