Cisco 6500 and 4500 switches
abousuhail
I have a weird problem with my switches, when i connect the NVR and the IP Cameras to any Cisco 6500 switch, the NVR never detect the IP Cameras
and when i connect them to any cisco 4500 switch, the NVR detects the IP Cameras immediately
I tried this on 4 Cisco 6500 switches
and 6 Cisco 4500 switches
I reset the configuration and i tried many IOSs on the 6500 switch but never works
can any body help me with any idea to make the Cisco 6500 switch let the NVR detect the IP Cameras?
hmmm the doc say its disabled maybe it is enabled fo that release your on
Note The IGMP snooping querier is disabled by default.
You can check whats turned on and hidden in ios with
sh run all
or
sh run full
12 Replies 12
Mark Malone
can the NVR ping the cameras when connected to the 6500  , how does it register / see them
what protocol does the NVR use to register see the cameras ?
is there any multicast enabled by default on the 4500s , do these cameras require multicast or can they work on unicast ?
are the macs and the ips resolved for the cameras when connected to the 6500 at a network level in cam and arp tables ?  is there any difference to there connections when compared to the 4500s
Thank you very much for your reply
i run the dhcp service on the 6500, the NVR and IP cameras got IP addresses from the pool, all of them are pingable, i can ping on all of them
the protocol called ONVIF
i made the same configuration on 6500 as 4500, but it doesn't work
i mad all ports switchport
i run the spanning tree portfast on all ports
i put all ports in the same vlan (1)
6500(config)#do sh run
Building configuration...
Current configuration : 7626 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 5
hostname 6500
boot-start-marker
boot-end-marker
username cisco privilege 15 password 0 123
no aaa new-model
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
ip subnet-zero
ip dhcp excluded-address 100.100.100.1 100.100.100.10
ip dhcp pool TST
network 100.100.100.0 255.255.255.0
default-router 100.100.100.1
ip flow ingress layer2-switched vlan 1
mls aging long 64
mls aging normal 32
mls netflow interface
mls flow ip interface-full
no mls flow ipv6
mls cef error action reset
system flowcontrol bus auto
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
archive
log config
logging enable
logging persistent auto
logging size 1000
notify syslog contenttype plaintext
redundancy
keepalive-enable
mode sso
main-cpu
auto-sync running-config
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
lldp run
interface GigabitEthernet3/1
no ip address
shutdown
interface GigabitEthernet3/2
no ip address
shutdown
interface GigabitEthernet3/3
no ip address
shutdown
interface GigabitEthernet3/4
no ip address
shutdown
interface GigabitEthernet3/5
no ip address
shutdown
interface GigabitEthernet3/6
no ip address
shutdown
interface GigabitEthernet3/7
no ip address
shutdown
interface GigabitEthernet3/8
no ip address
shutdown
interface GigabitEthernet3/9
no ip address
shutdown
interface GigabitEthernet3/10
no ip address
shutdown
interface GigabitEthernet3/11
no ip address
shutdown
interface GigabitEthernet3/12
no ip address
shutdown
interface GigabitEthernet3/13
no ip address
shutdown
interface GigabitEthernet3/14
no ip address
shutdown
interface GigabitEthernet3/15
no ip address
shutdown
interface GigabitEthernet3/16
no ip address
shutdown
interface FastEthernet4/1
switchport
interface FastEthernet4/2
switchport
interface FastEthernet4/3
switchport
interface FastEthernet4/4
switchport
interface FastEthernet4/5
switchport
interface FastEthernet4/6
switchport
interface FastEthernet4/7
switchport
interface FastEthernet4/8
switchport
interface FastEthernet4/9
switchport
interface FastEthernet4/10
switchport
interface FastEthernet4/11
switchport
interface FastEthernet4/12
switchport
interface FastEthernet4/13
switchport
interface FastEthernet4/14
switchport
interface FastEthernet4/15
switchport
interface FastEthernet4/16
switchport
interface FastEthernet4/17
switchport
interface FastEthernet4/18
switchport
interface FastEthernet4/19
switchport
interface FastEthernet4/20
switchport
interface FastEthernet4/21
switchport
interface FastEthernet4/22
switchport
interface FastEthernet4/23
switchport
interface FastEthernet4/24
switchport
interface FastEthernet4/25
switchport
interface FastEthernet4/26
switchport
interface FastEthernet4/27
switchport
interface FastEthernet4/28
switchport
interface FastEthernet4/29
switchport
interface FastEthernet4/30
switchport
interface FastEthernet4/31
switchport
interface FastEthernet4/32
switchport
interface FastEthernet4/33
switchport
interface FastEthernet4/34
switchport
interface FastEthernet4/35
switchport
interface FastEthernet4/36
switchport
interface FastEthernet4/37
switchport
interface FastEthernet4/38
switchport
interface FastEthernet4/39
switchport
interface FastEthernet4/40
switchport
interface FastEthernet4/41
switchport
interface FastEthernet4/42
switchport
interface FastEthernet4/43
switchport
interface FastEthernet4/44
switchport
interface FastEthernet4/45
switchport
interface FastEthernet4/46
switchport
interface FastEthernet4/47
switchport
interface FastEthernet4/48
switchport
interface TenGigabitEthernet5/1
no ip address
shutdown
interface TenGigabitEthernet5/2
no ip address
shutdown
interface GigabitEthernet5/3
no ip address
shutdown
interface FastEthernet9/1
switchport
interface FastEthernet9/2
switchport
interface FastEthernet9/3
switchport
interface FastEthernet9/4
switchport
interface FastEthernet9/5
switchport
interface FastEthernet9/6
switchport
interface FastEthernet9/7
switchport
interface FastEthernet9/8
switchport
interface FastEthernet9/9
switchport
interface FastEthernet9/10
switchport
interface FastEthernet9/11
switchport
interface FastEthernet9/12
switchport
interface FastEthernet9/13
switchport
interface FastEthernet9/14
switchport
interface FastEthernet9/15
switchport
interface FastEthernet9/16
switchport
interface FastEthernet9/17
switchport
interface FastEthernet9/18
switchport
interface FastEthernet9/19
switchport
interface FastEthernet9/20
switchport
interface FastEthernet9/21
switchport
interface FastEthernet9/22
switchport
interface FastEthernet9/23
switchport
interface FastEthernet9/24
switchport
interface FastEthernet9/25
switchport
interface FastEthernet9/26
switchport
interface FastEthernet9/27
switchport
interface FastEthernet9/28
switchport
interface FastEthernet9/29
switchport
interface FastEthernet9/30
switchport
interface FastEthernet9/31
switchport
interface FastEthernet9/32
switchport
switchport mode access
interface FastEthernet9/33
switchport
interface FastEthernet9/34
switchport
interface FastEthernet9/35
switchport
interface FastEthernet9/36
switchport
interface FastEthernet9/37
switchport
interface FastEthernet9/38
switchport
interface FastEthernet9/39
switchport
interface FastEthernet9/40
switchport
interface FastEthernet9/41
switchport
interface FastEthernet9/42
switchport
interface FastEthernet9/43
switchport
interface FastEthernet9/44
switchport
interface FastEthernet9/45
switchport
interface FastEthernet9/46
switchport
interface FastEthernet9/47
switchport
interface FastEthernet9/48
switchport
interface Vlan1
ip address 100.100.100.254 255.255.255.0
ip classless
no ip http server
ip flow-export version 5
control-plane
line con 0
line vty 0 4
login local
line vty 5 15
login local
end
6500(config)#
I don't see anything on that switch that could be blocking theres not even an acl in place
Is there any difference in the 4500 config if you can post it please  ?
don't post your passwords in the config just for security reasons
what do you use to view the cameras is it https or do you login into the NVR itself , just trying to understand what the way its working on the 4500 exactly
if you can ping everything the switch is working as it should right up to layer 3 but something at higher layer maybe failing
what vendor and platform is the NVR system
they both (4500 and 6500) have the same configuration exactly
Sporting_4506#sh run
Current configuration : 22216 bytes
! Last configuration change at 06:50:08 UTC Sat Feb 25 2017 by it
! NVRAM config last updated at 06:40:08 UTC Sat Feb 25 2017 by it
version 12.2
no service pad
service password-encryption
service compress-config
hostname Sporting_4506
boot-start-marker
boot bootldr bootflash:cat4000-i9k91s-mz.122-25.EWA1.bin
boot-end-marker
no aaa new-model
vtp domain
vtp mode transparent
ip subnet-zero
ip ftp source-interface Vlan60
ip ftp username admin
ip ftp password 7 02575608
no file verify auto
power redundancy-mode combined
vlan 60
name NETWORK
vlan 61
name CAM
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface FastEthernet2/1
switchport access vlan 61
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
interface FastEthernet2/8
interface FastEthernet2/9
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface FastEthernet2/15
interface FastEthernet2/16
interface FastEthernet2/17
interface FastEthernet2/18
interface FastEthernet2/19
interface FastEthernet2/20
interface FastEthernet2/21
interface FastEthernet2/22
interface FastEthernet2/23
interface FastEthernet2/24
interface FastEthernet2/25
interface FastEthernet2/26
interface FastEthernet2/27
interface FastEthernet2/28
interface FastEthernet2/29
interface FastEthernet2/30
interface FastEthernet2/31
interface FastEthernet2/32
interface FastEthernet2/33
interface FastEthernet2/34
interface FastEthernet2/35
interface FastEthernet2/36
interface FastEthernet2/37
interface FastEthernet2/38
interface FastEthernet2/39
interface FastEthernet2/40
interface FastEthernet2/41
interface FastEthernet2/42
switchport access vlan 60
interface FastEthernet2/43
interface FastEthernet2/44
interface FastEthernet2/45
interface FastEthernet2/46
interface FastEthernet2/47
interface FastEthernet2/48
interface FastEthernet3/1
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface FastEthernet3/5
interface FastEthernet3/6
interface FastEthernet3/7
interface FastEthernet3/8
interface FastEthernet3/9
interface FastEthernet3/10
interface FastEthernet3/11
interface FastEthernet3/12
interface FastEthernet3/13
interface FastEthernet3/14
interface FastEthernet3/15
interface FastEthernet3/16
interface FastEthernet3/17
interface FastEthernet3/18
interface FastEthernet3/19
interface FastEthernet3/20
interface FastEthernet3/21
interface FastEthernet3/22
interface FastEthernet3/23
interface FastEthernet3/24
interface FastEthernet3/25
interface FastEthernet3/26
interface FastEthernet3/27
interface FastEthernet3/28
interface FastEthernet3/29
interface FastEthernet3/30
interface FastEthernet3/31
interface FastEthernet3/32
interface FastEthernet3/33
interface FastEthernet3/34
interface FastEthernet3/35
interface FastEthernet3/36
interface FastEthernet3/37
interface FastEthernet3/38
interface FastEthernet3/39
interface FastEthernet3/40
interface FastEthernet3/41
interface FastEthernet3/42
interface FastEthernet3/43
interface FastEthernet3/44
interface FastEthernet3/45
interface FastEthernet3/46
interface FastEthernet3/47
interface FastEthernet3/48
interface FastEthernet5/1
interface FastEthernet5/2
interface FastEthernet5/3
interface FastEthernet5/4
interface FastEthernet5/5
interface FastEthernet5/6
interface FastEthernet5/7
interface FastEthernet5/8
interface FastEthernet5/9
interface FastEthernet5/10
interface FastEthernet5/11
interface FastEthernet5/12
interface FastEthernet5/13
interface FastEthernet5/14
interface FastEthernet5/15
interface FastEthernet5/16
interface FastEthernet5/17
interface FastEthernet5/18
interface FastEthernet5/19
interface FastEthernet5/20
interface FastEthernet5/21
interface FastEthernet5/22
interface FastEthernet5/23
interface FastEthernet5/24
interface FastEthernet5/25
interface FastEthernet5/26
interface FastEthernet5/27
interface FastEthernet5/28
interface FastEthernet5/29
interface FastEthernet5/30
interface FastEthernet5/31
interface FastEthernet5/32
interface FastEthernet5/33
interface FastEthernet5/34
interface FastEthernet5/35
interface FastEthernet5/36
interface FastEthernet5/37
interface FastEthernet5/38
interface FastEthernet5/39
interface FastEthernet5/40
interface FastEthernet5/41
interface FastEthernet5/42
interface FastEthernet5/43
interface FastEthernet5/44
interface FastEthernet5/45
interface FastEthernet5/46
interface FastEthernet5/47
interface FastEthernet5/48
interface FastEthernet6/1
interface FastEthernet6/2
interface FastEthernet6/3
interface FastEthernet6/4
interface FastEthernet6/5
interface FastEthernet6/6
interface FastEthernet6/7
interface FastEthernet6/8
interface FastEthernet6/9
interface FastEthernet6/10
interface FastEthernet6/11
interface FastEthernet6/12
interface FastEthernet6/13
interface FastEthernet6/14
interface FastEthernet6/15
interface FastEthernet6/16
interface FastEthernet6/17
interface FastEthernet6/18
interface FastEthernet6/19
interface FastEthernet6/20
interface FastEthernet6/21
interface FastEthernet6/22
interface FastEthernet6/23
interface FastEthernet6/24
interface FastEthernet6/25
interface FastEthernet6/26
interface FastEthernet6/27
interface FastEthernet6/28
interface FastEthernet6/29
interface FastEthernet6/30
interface FastEthernet6/31
interface FastEthernet6/32
interface FastEthernet6/33
interface FastEthernet6/34
interface FastEthernet6/35
interface FastEthernet6/36
interface FastEthernet6/37
interface FastEthernet6/38
interface FastEthernet6/39
interface FastEthernet6/40
interface FastEthernet6/41
interface FastEthernet6/42
interface FastEthernet6/43
interface FastEthernet6/44
interface FastEthernet6/45
interface FastEthernet6/46
interface FastEthernet6/47
interface FastEthernet6/48
interface Vlan1
no ip address
interface Vlan10
no ip address
shutdown
interface Vlan60
ip address 10.174.16.254 255.255.255.0
interface Vlan61
ip address 10.175.16.254 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.174.16.1
ip route 0.0.0.0 0.0.0.0 10.175.16.1
no ip http server
kron occurrence Backup at 1:10 recurring
kron policy-list Backup
cli copy running-config ftp://10.10.30.200
cli copy running-config ftp://10.10.30.220
banner motd ^CCCC
#############################FATHALLA GOMLA MARKET#############################
### Sporting Switch 4506 "Sporting_4506" ###
### This is a protected device, any unauthorized access ###
### is prohipted and puts you under the authority of law. ###
#########################################################################################^C
line con 0
stopbits 1
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
end
NVR and IPCAM vendor called OLI!!
You have 2 vlans created on the 4500 but only 1 on the 6500 , are the cameras and NVR on the same subnet yes ?
whats this ip 10.174.16.1 is it a FW , traffic is definitely not being pushed to this first on the 4500 to process ?
yes i made 2 vlans on 6500 also but it doesn't work too
i made it now one vlan for simplicity
10.174.16.1 is the cisco 2801 router,
There is nothing obvious there causing the issue that I can see in your configuration at all it couldn't be more basic in setup , if everything is in the same broadcast domin same subnet there's nothing that could block it from switch perspective
Personally if it was my issue on my step I would capture the traffic through a wirehshark from the 4500 and compare it to the 6500 and see what exactly is happening when there trying to communicate with each other
is there any configuration on the system itself , that needs to be changed when moving it from the 45 to the 65 ? something has to be preventing it and the switch is clean , no acls in pace nothing that's restricting protocols or traffic between ports
I very much thank your help and i will try the wireshark, if it works i let you know
Thanks again
Hi Mark Malone,
i just want to tell you that my problem was recovered :)
i put this command on the 6500 switch and the NVR detects all the IPCam immediately
Thanks for your help
6500(config)#no ip igmp snooping
thanks for posting back the fix
thats odd as that's disabled by default in ios and shouldn't been in use unless someone turned it on , I don't see it in the running-config you posted earlier either
but i made write erase for the configuration on all the 6500s before i connect the NVR and IPcams
I thought may be it is running in background by default on the 6500 IOSs !!!!!!
sh run all
or
sh run full
