Cisco 6500 Sup720 BOOT Variable Problem
drhague
I have a VS-S720-10G supervisor with version 12.2(33)SXH IOS. The BOOT variable looks like this:
BOOT variable = flash:s72033-ipservices_wan-mz.122-33.SXH.bin;-mz.122-33.SXI.bin,12;flash:s72033-advipservicesk9_wan-mz.122-33.SXI.bin;s72033-ipservices_wan-mz.
122-33.SXH.bin,12;flash:,12;
It's obviously messed up, so I want to remove all the variables and start fresh. I want the boot variable to read "BOOT variable = sup-bootdisk:s72033-ipservices_wan-mz.122-33.SXH.bin"
The problem is, I can't remove the variables. I try a "no boot system flash xxxxxx" (substituting a variable string for the x's), then do a write, but "show boot" shows no change. I've even tried "no boot system flash <everything after the equal sign>", to no effect.
What am I doing wrong?
Try it like this
no boot system flash sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI.bin
without the ,1 at the end.
Mark
5 Replies 5
Mark Yeates
Level 11
Level 11
Dave,
Are you removing the old ones and then configuring the new boot strings? If not try adding the new ones and save the config. Then check the output of "show boot".
Mark
Mark:
I did as you suggested, and my boot variable now looks like
122-33.SXH.bin,12;flash:,12;sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI.bin,1;
The statement was appended to the existing boot variable.
If I type "no boot system flash sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI.bin,1;" and write/show boot, the boot variable is unchanged.
Dave
Try it like this
Mark
Mark.
Hey! That worked! I feel like such a noob. I was able to remove the remainder of the boot variables by not including the ",number" at the end.
Thanks a lot. If you're ever in Edmonton, look me up and I'll buy you a libation of your choosing.
Dave
Glad I was able to help. I will take you up on your off if I ever venture that far north.
Mark
