Cisco 6500 Switch setup question
fullerton175
Community Member
We currently are attempting to replace an older 5509 with a 6500 series switch (all version information will be below) but I am coming across a problem that I'd appreciate the community's help on please.
I'll start with posting the configuration of the new switch then describe the problem.
Current configuration : 9033 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service counters max age 5
hostname Router
no aaa new-model
ip subnet-zero
mls ip slb purge global
no mls acl tcam share-global
redundancy
mode sso
main-cpu
auto-sync running-config
spanning-tree mode pvst
no spanning-tree vlan 1,22
no diagnostic cns publish
no diagnostic cns subscribe
fabric timer 15
vlan internal allocation policy ascending
interface GigabitEthernet1/1
description VLAN22 Dungeon Connection
switchport
switchport trunk allowed vlan 22
switchport mode trunk
no ip address
interface GigabitEthernet1/2
no ip address
shutdown
interface FastEthernet2/1
switchport
switchport access vlan 22
no ip address
<<other fast ethernet ports omitted>>
interface Vlan1
no ip address
interface Vlan22
description Dungeon Switch
ip address 192.168.22.4 255.255.255.0
ip helper-address 192.168.20.24
ip directed-broadcast 101
router rip
version 2
network 192.168.20.0
network 192.168.22.0
ip default-gateway 192.168.22.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.22.1
no ip http server
access-list 101 permit udp host 192.168.20.93 any eq snmp
dial-peer cor custom
line con 0
line vty 0 4
login
no cns aaa enable
end
The problem is this: after I setup the switch the VLAN I want to establish (VLAN 22) shows to be down/down when I do a show interface command.
The G1/1 interface (the gig interface on the Supervisor) shows to be up/up as does the FastEthernet port 2/1 when I plug in my laptop. However, since the VLAN is down I can't communicate back to the core switch which is on the other end of the connection (a 6506E)
The new switch has the following version settings:
IOS (tm) s222_rp Software (s222_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF16, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Tue 03-Mar-09 14:24 by kellythw
Image text-base: 0x40101040, data-base: 0x4295C840
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: s222_rp Software (s222_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF16, RELEASE SOFTWARE (fc2)
Router uptime is 17 hours, 49 minutes
Time since Router switched to active is 17 hours, 48 minutes
System returned to ROM by power cycle (SP by power-on)
System image file is "disk0:s222-ipservices_wan-mz.122-18.SXF16.bin"
cisco WS-C6506 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
Processor board ID SAL08239FVP
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
2 Virtual Ethernet/IEEE 802.3 interfaces
144 FastEthernet/IEEE 802.3 interfaces
2 Gigabit Ethernet/IEEE 802.3 interfaces
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
5 Replies 5
dario.didio
Level 9
Level 9
Did you create the VLAN?
conf t
vlan 22
name data
keep us posted!
HTH,
Dario
glen.grant
Verify vlan is created with a show vlan command . The ports don't have spanning tree portfast on them so you may have to wait about 50 seconds while that runs before the L3 interface will come active . Otherwise there is no reason for the L3 interface not to come up . If you have that trunk connection up and active then the L3 interface should be active.
(message edited 6/18/09, 9:20AM CST
I had to disconnect all connections to the switch and bring the old one back online but I think I found the problem.
The VLAN was created but was showing down/down.
Now, when I first powered on the 6500 the GBIC interface was not physically plugged into the module on the supervisor engine (the g1/1 interface). I had plugged it into the module after the switch was already powered online
So, on a hunch I physically shut down the switch and brought it back online. All systems booted normally so that was good.
I then did:
show int
After the reboot VLAN 22 shows to be up/down which I believe is correct until I can plug in the uplink (the g1/1) to the network again and but that would have to wait until off hours since I obviously can't unplug the old siwtch during business hours.
Am I correct in that assessment about the status of the vlan 22?
When I perform a show vlan the GI1/1 shows to be in VLAN1 still too. I don't believe that should be the case
This problem has been resolved. The solution was, as I thought, pretty simple.
When testing your VLANs and connections, you have to be sure to have a device plugged into one of the ports on the switch. I don't know why this is but I'm guessing it has something to do with spanning trees.
I also placed the switch in transparent mode for vtp as well tweaked the settings a little to be this for the switch:
vlan 22
switchport
switchport
switchport mode access
interface Vlan22
After these changes the switch worked great again. Thanks for all the assistance!
'When testing your VLANs and connections, you have to be sure to have a device plugged into one of the ports on the switch.'
Well, it actually has to do with the fact that if nothing is connected to an interface, then it is down. In the case of a VLAN, the way to connect something to it is to have something active on either an access port in that VLAN or a trunk port on which that VLAN is allowed.
So if your physical problem with a port was causing no trunkports to be active, and you at the same time did not have any access port which is in VLAN 22 active, then the interface VLAN 22 will show up/down.
Your good old 2501 router did the same with it's e0 interface, if you did not connect anything to it.
HTH.
