11-27-2011 11:01 AM - edited 03-07-2019 03:37 AM
My Cisco 6506 switch got rebooted with the message as below:
%SPANTREE-5-EXTENDED_SYSID:
Configured from memory by console
System restarted...
Can any one suggest the root cause. Logs attached.
Solved! Go to Solution.
11-27-2011 07:12 PM
In addition to Leo's good recommendation and to eliminated any fabric channel hardware issues, move the sup to slot 5 and see if the issue reappears
11-27-2011 11:08 AM
Below is the info collected form Crash info:
Nov 27 17:44:21 IST: %FABRIC-SP-3-DISABLE_FAB: The fabric manager disabled active fabric in slot 6 due to the error (2) on this channel (FPOE 4) connected to slot 6
Nov 27 17:44:21.098 IST: SP: Supervisor has bad local fabric channel. StbyRdyForSwOver 0, StbyLocalFabLinkOk 0
%Software-forced reloa
11-27-2011 11:50 AM
Try re-seating the module 6.If it works then fine orelse open a TAC.
11-27-2011 11:54 AM
switch is working fine but want to analyse the actual reason for reload.
11-27-2011 06:03 PM
what type of module is in slot 6?
11-27-2011 06:13 PM
It is WS-SUP720-BASE
11-27-2011 06:18 PM
so you have 2 sups with redundant sup in slot 6?
if yes, are they in redundant SSO mode?
11-27-2011 06:20 PM
Only two modules are there WS-X6724-SFP in slot 2 and SUP720-Base slot 6
11-27-2011 06:25 PM
*Nov 27 16:41:36 IST: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for typt change the spanning tree topology
*Nov 27 16:41:37 IST: %SYS-5-CONFIG_I: Configured from memory by console
*Nov 27 16:41:41 IST: %SYS-5-RESTART: System restarted --
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXH1, RELEASE SOFTWARE (fc3)
Is that all? You want answers as to why the chassis rebooted and this is the only information you can furnish?
11-27-2011 06:28 PM
Sh tech support of the device is already attached.
11-27-2011 06:52 PM
Cool! More information.
Here's my take (until Reza and others can chime in) ...
1. You are running IOS SXH1. This IOS has been released sometime early 2008.
2. The version of IOS you are running has been removed by Cisco possibly because there are some glaring bugs.
3. The crash happens after the log entry:
My recommendation is for you to upgrade your IOS to something more "current".
11-27-2011 07:12 PM
