Cisco 6506 Stuck in rommon due to bootdisk fails
mohammadSaeed01
Hi guys
I was having one issue in core 6506 model. I removed the cf card and I format it then i upload a new fw after that i inset it but the rommon mode could not read bootdisk and bootflash as well...How can I solve it?
19 Replies 19
Mark Elsen
 - Check this document : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Config_Notes/6507_01.html , pay attention to supported Flash card(s) mentioned and installation procedure (format).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The doc talked about the slot0 cf but i removed the inside cf which comes with sup.
What is the Supervisor card model?
Cat6k-sup720/sp this is the model of sup
What error message when an external CF is used?
Actually i removed the internal cf 1g and i format it in my laptop then i copied a new ios bin file then i rensert it i side not from outside and gives me error bootdisk doesnt contain a valid magic number and before i was able to make dir bootflash: but now even bootflash is not there any more
Corrupt partition or the file is corrupt.
Console into the supervisor card and attempt to boot the IOS using the external CF.  Post the entire boot-up process.
Can I use the interal cf to insert it external because I dont have anpther cf to use it in external?
And how will you be able to determine if the internal CF did not fail?
You are right! So what is the best and guarantee CF I can use it in external CF? I have Transcend 4G CF, can I use it?
Yes, as long as the CF is formatted to FAT16.
Oh, OK, and also the internal CF should be FAT16? because I format the internal CF with FAT32 maybe that's why the bootflash: not detect it!
I will check the FAT version in Internal CF tomorrow! I am afraid it's 32!
I format it to FAT16 and here is the logs I have on console:
rommon 7 > reset
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
device does not contain a valid magic number
boot: cannot open "bootdisk:"
boot: cannot determine first file name on device "bootdisk:"
Autoboot executing command: "boot bootdisk:"
rommon 1 > dir
usage: dir <device>
rommon 2 > dir disk0:
dir: cannot open device "disk0:"
rommon 3 > dir slot0:
bad device name (device not supported)
usage: dir <device>
rommon 4 > dir
usage: dir <device>
rommon 5 >
rommon 5 >
rommon 5 >
rommon 5 >
rommon 5 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
SLOTCACHE=cards;
RANDOM_NUM=1542863794
BOOT=
NT_K=0:0:0:0
BSI=0
PF_REDUN_CRASH_COUNT=0
CRASHINFO=bootflash:crashinfo_20221115-073627
RET_2_RTS=07:36:29 UTC Tue Nov 15 2022
RET_2_RCALTS=1668497792
?=1
rommon 6 > sync
rommon 7 > dir bootflash:
dir: cannot open device "bootflash:"
rommon 8 > dir disk0:
rommon 9 > dir slot0:
usage: dir <device>
rommon 10 > dir disk1:
PCMCIA disk1: device is not initialized
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "disk1:"
rommon 11 > dir disk0:
rommon 12 > dir disk0:
PCMCIA disk0: device is not initialized
rommon 13 >
rommon 13 >
rommon 13 >
rommon 13 >
rommon 13 >
rommon 13 > dir disk0:
rommon 14 >
