Cisco 6506 Stuck in rommon due to bootdisk fails
mohammadSaeed01
Hi guys
I was having one issue in core 6506 model. I removed the cf card and I format it then i upload a new fw after that i inset it but the rommon mode could not read bootdisk and bootflash as well...How can I solve it?
19 Replies 19
I took the internal CF 1G from Core sw has an issue and I insert it as external in another Core switch to check the CF if work, and it works from Another core but as external but when I add it inside the corrupted core sw it gives me no bootdisk: ?
mohammadSaeed01
I also did this command:
rommon 3 > boot disk
Loading image, please wait ...
Invalid device specified
Booting from default device
device does not contain a valid magic number
boot: cannot open "bootdisk:"
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "disk"
rommon 4 >
but no luck!
And I tried this also:
Configuration Summary
enabled are:
diagnostic mode
use net in IP bcast address
load rom after netboot fails
use all zero broadcast
break/abort has effect
ignore system config info
console baud: 9600
boot: the boot helper image
do you wish to change the configuration? y/n [n]: n
You must reset or power cycle for new config to take effect
rommon 11 > sync
rommon 12 > boot disk
rommon 13 > reset
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory for cache initialization
Clearing bss
Clearing autoboot state machine
melody_present_reg: 1st read w/ 0x5555
melody_present_reg: 2nd read w/ 0xaaaa, reversed: 0x5555
Bootdisk adapter is detected, enabling bootdisk access...
Reprogramming CS1 w/ Melody value...
Reading monitor variables from NVRAM
Reset reason for CPU board 0xffff , BaseBoard 0x281ffff, display 0x20000System Reset by Software.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
MOBILE dimm - rev 0.15
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Initializing USB2.0 controller
Exiting init
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:"
boot: cannot determine first file name on device "bootdisk:"
Clearing bss melody_present_reg: 1st read w/ 0x5555
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
rommon 1 >
What is this history of this line card?  Was this purchased from a used-equipment dealer?
No, it was working before but they shift it to new place with wrong way and we lost the ios file and I am trying to let it work again!
