Cisco 6506, VS-S720-10G replacement
abdullahsn91
  • I have 2 core switches of model  catalyst 6506-e. Both are interconnected by VSS.
Each core switch have 2 supervisor engine module VS-S720-10G. Total 4 supervisor engine module. If one module in switch A failed then the other switch B module takeover.
The problem is one module in switch B is faulty. Which is not active. And i want to replace it without downtime.
Question: how can i replace it ?
6 Replies 6
 Highly recommend you to read this document.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/117850-config-quadsupvss-00.html
Then come after before with specific questions.
Leo Laohoo
Make sure the replacement line card has the same IOS version as the rest of the VSS.
Make sure the replacement line card has the same DFC/PFC card as the rest.
Need help. If the new line card have different ios then how to replace the ios with the current version
Secondly, how the new card will take configuration? Should it take by itself from active supervisor engine or i have to write command for it
Look at the Sup720.  Does it have a CF slot?
Yes it have the CF slot. I also need to know how to copy configuration to disk0/cf and how to retrive it.
copy flash:filename.bin disk0:
