Virtual Stackwise not Synchronizing
dannyh
Level 3
Level 3
Recently I was advised on this forums to switch over to Virtual Stackwise from HSRP on the Core Switches we have running on the network. I have deleted all of the HSRP configurations and wiped the switch that is going to be the standby switch (call it Core Switch 2).
So far I have configured interfaces on both Core Switch 1 and 2 to have the SVL. DAD cannot be in place for the moment due to the physical limitation between the buildings (Core Switch 1 and 2 are in separate buildings for power redundancy). I have Configured the Switch Virtual-Stackwise and it's domain (101). I have prioritized Core Switch 1 to be 15 and renumbered and reprioritized Core Switch 2 as Switch 2 and Priority 14.
The issue is that when the connection between the switches are made, they are not synchronizing. I see Core Switch 2 displaying both interfaces numbered ten1/0/1 - 40 and ten2/0/1 - 40. I see in Core Switch 2's 'show switch' command that the switch 1 has no mac address but Core Switch 2 does. But in Core Switch 1, I only see Core Switch 1 in 'show switch' and I don't see interfaces ten2/0/1 - 40 like I do in Core Switch 2.
I tried to save and reload the switches multiple times and redo the configurations. What can I do in order to get these two switches synchronized where Core Switch 1 and 2 are sharing configurations (same control plane) like how Cisco documents are saying? Switches in use are Cisco Catalyst 9500 40 ports. I have checked the licensing, models, and the IOS and they are all same between the switches.
Oh no, look like we have the 9500-40X models. So even if we get the module for the extended interfaces, we can't form SVL between the switches?
It appears to be so, but I would also open a ticket with TAC and make sure that is actually the case.
9 Replies 9
balaji.bandi
You need to post the config, show version for us to verify. (Once SVL  build switch will reboot, standby one you can not enter any commands at all (in your case different as you mentioned)
Follow exactly below guide it works :  (just make sure you go with latest verison 17.6.X)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.html
here is my test setup :
https://www.balajibandi.com/?p=931
BB
Reza Sharifi
What is the output of "show stack-virtual and show stack-virtual link"?
Also, you can post "sh run"?
CoreSW1 Show Run:
version 17.6
service timestamps log datetime localtime show-timezone
service password-encryption
service call-home
no platform punt-keepalive disable-kernel-core
hostname
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa session-id common
boot system switch all flash:packages.conf
clock timezone PST -8 0
clock summer-time PDT recurring
switch 1 provision c9500-40x
stackwise-virtual
domain 101
dual-active detection pagp trust channel-group 1
ip routing
ip nbar http-services
ip name-server 199.47.34.43 199.47.34.40
ip domain name mil.wa.lcl
login on-success log
qos queue-softmax-multiplier 400
license boot level network-advantage addon dna-advantage
diagnostic bootup level minimal
spanning-tree mode pvst
spanning-tree vlan
spanning-tree vlan
memory free low-watermark processor 132525
redundancy
mode sso
transceiver type all
monitoring
vlan dot1q tag native
interface Port-channel1
interface Port-channel41
switchport mode trunk
interface Port-channel43
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
shutdown
interface TenGigabitEthernet1/0/3
channel-group 41 mode active
interface TenGigabitEthernet1/0/4
interface TenGigabitEthernet1/0/5
interface TenGigabitEthernet1/0/6
interface TenGigabitEthernet1/0/7
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/0/9
interface TenGigabitEthernet1/0/10
interface TenGigabitEthernet1/0/11
interface TenGigabitEthernet1/0/12
interface TenGigabitEthernet1/0/13
interface TenGigabitEthernet1/0/14
interface TenGigabitEthernet1/0/15
description Link_To_ASA
interface TenGigabitEthernet1/0/16
interface TenGigabitEthernet1/0/17
interface TenGigabitEthernet1/0/18
interface TenGigabitEthernet1/0/19
shutdown
interface TenGigabitEthernet1/0/20
interface TenGigabitEthernet1/0/21
interface TenGigabitEthernet1/0/22
interface TenGigabitEthernet1/0/23
interface TenGigabitEthernet1/0/24
no switchport
ip address
ip nbar protocol-discovery
interface TenGigabitEthernet1/0/25
interface TenGigabitEthernet1/0/26
interface TenGigabitEthernet1/0/27
interface TenGigabitEthernet1/0/28
interface TenGigabitEthernet1/0/29
interface TenGigabitEthernet1/0/30
interface TenGigabitEthernet1/0/31
interface TenGigabitEthernet1/0/32
no switchport
ip address
interface TenGigabitEthernet1/0/33
channel-group 43 mode active
interface TenGigabitEthernet1/0/34
interface TenGigabitEthernet1/0/35
interface TenGigabitEthernet1/0/36
interface TenGigabitEthernet1/0/37
channel-group 1 mode desirable
interface TenGigabitEthernet1/0/38
stackwise-virtual dual-active-detection
description Link_To_CoreSW2
interface TenGigabitEthernet1/0/39
stackwise-virtual link 1
interface TenGigabitEthernet1/0/40
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
ip ssh time-out 60
ip ssh version 2
ip scp server enable
control-plane
service-policy input system-cpp-policy
end
Core SW 1 Show Stackwise-Virtual:
Stackwise Virtual Configuration:
Stackwise Virtual : Enabled
Domain Number : 101
Switch Stackwise Virtual Link Ports
1 1 TenGigabitEthernet1/0/39
Core Switch 1 Show Stackwise-Virtual Link:
Stackwise Virtual Link(SVL) Information:
Flags:
Link Status
U-Up D-Down
Protocol Status
S-Suspended P-Pending E-Error T-Timeout R-Ready
Switch SVL Ports Link-Status Protocol-Status
1 1 TenGigabitEthernet1/0/39 D S
TenGigabitEthernet1/0/40 D S
Core Switch 2 Show Run:
Switch#show run
Building configuration...
Current configuration : 12073 bytes
! Last configuration change at 00:16:02 UTC Thu Mar 30 2023
version 17.6
service call-home
hostname Switch
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch 2 provision c9500-40x
stackwise-virtual
domain 101
spanning-tree mode rapid-pvst
memory free low-watermark processor 131709
redundancy
mode sso
monitoring
policy-map system-cpp-policy
no ip address
shutdown
negotiation auto
description Link to DistSW1
description Link to DistSW2
interface TenGigabitEthernet2/0/1
interface TenGigabitEthernet2/0/2
interface TenGigabitEthernet2/0/3
interface TenGigabitEthernet2/0/4
interface TenGigabitEthernet2/0/5
interface TenGigabitEthernet2/0/6
interface TenGigabitEthernet2/0/7
interface TenGigabitEthernet2/0/8
interface TenGigabitEthernet2/0/9
interface TenGigabitEthernet2/0/10
interface TenGigabitEthernet2/0/11
interface TenGigabitEthernet2/0/12
interface TenGigabitEthernet2/0/13
interface TenGigabitEthernet2/0/14
interface TenGigabitEthernet2/0/15
interface TenGigabitEthernet2/0/16
interface TenGigabitEthernet2/0/17
interface TenGigabitEthernet2/0/18
interface TenGigabitEthernet2/0/19
interface TenGigabitEthernet2/0/20
interface TenGigabitEthernet2/0/21
interface TenGigabitEthernet2/0/22
interface TenGigabitEthernet2/0/23
interface TenGigabitEthernet2/0/24
interface TenGigabitEthernet2/0/25
interface TenGigabitEthernet2/0/26
interface TenGigabitEthernet2/0/27
interface TenGigabitEthernet2/0/28
interface TenGigabitEthernet2/0/29
interface TenGigabitEthernet2/0/30
interface TenGigabitEthernet2/0/31
interface TenGigabitEthernet2/0/32
interface TenGigabitEthernet2/0/33
interface TenGigabitEthernet2/0/34
interface TenGigabitEthernet2/0/35
interface TenGigabitEthernet2/0/36
interface TenGigabitEthernet2/0/37
interface TenGigabitEthernet2/0/38
interface TenGigabitEthernet2/0/39
description Link To CoreSW1
interface TenGigabitEthernet2/0/40
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface TenGigabitEthernet2/1/5
interface TenGigabitEthernet2/1/6
interface TenGigabitEthernet2/1/7
interface TenGigabitEthernet2/1/8
interface FortyGigabitEthernet2/1/1
interface FortyGigabitEthernet2/1/2
end
Core SW 2 show stackwise-virtual:
Switch#show stackwise-virtual
Domain Number : 101
2 1 TenGigabitEthernet2/0/39
Core Switch 2 show stackwise-virtual link:
Domain Number : 101
Switch#show stackwise-virtual link
Flags:
Link Status
U-Up D-Down
Protocol Status
2 1 TenGigabitEthernet2/0/39 D S
TenGigabitEthernet2/0/40 D S
Are the physical links (2/0/39, 40 and 1/0/39, 40) are all up and running?
What is the output of "sh ip int brief ten1/0/39" and 1/0/40?
What model 9500 are these switches. See below link for restrictions:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-10/configuration_guide/ha/b_1610_ha_9500_cg/configuring_cisco_stackwise_virtual.html
Restrictions for Cisco Catalyst 9500 Series Switches
  • When configuring StackWiseVirtual links (SVLs) on 9500-40X and C9500-16X models of the Cisco Catalyst 9500 Series Switches, note that you cannot create SVLs on any of the network modules.
  • 4x10G breakout cables are not supported with SVL mode.
Restrictions for Cisco Catalyst 9500 Series High Performance Switches
  • 4x25G and 4x10G breakout cables are not supported with SVL mode.
  • On C9500-32C switches, you can configure SVL and DAD only on interfaces numbered 1-16 on the front panel of the switch.
  • On C9500-32QC, you can configure SVL and DAD only on native 100G and 40G interfaces (default configuration ports). You cannot configure SVL and DAD on converted 100G and 40G interfaces.
  • On Cisco Catalyst 9500 Series High Performance Switches, configuring SVL using 1G interfaces is not supported.
Thank you for your assistance. I was so caught up on trying to fix the issue that I didn't look into the capabilities of the switches we have.
Sure! When I was going through your config, I remembered that there are some limitations on these boxes and had seen a few posts where people were trying to configure the VSL links and it wasn't working for them.
Good luck and let us know if you have more questions.
