Cisco 6509 + 10GB modules
ross_rulz
Hi Guys,
Can someone please tell me if its possible to have a 8 port 10GB module for our 6509? If not what do I need to do to get it working with this module? Any help would be appreciated.
Cheers,
Ross.
CH-6509#show mod
Mod Ports Card Type                              Model              Serial No.
  1    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL06240ZNC
  2   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL0805TR3N
  3   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1328TT1C
  4   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1118MZJW
  5    2  Supervisor Engine 720 (Hot)            WS-SUP720-BASE     SAD081005AU
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAD082008VB
  7   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL1407BJ30
  8   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAD0816060G
  9   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAD07470450
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0009.11bf.8980 to 0009.11bf.8987   2.1   5.4(2)       8.3(0.156)RO Ok
  2  0008.7dca.87fc to 0008.7dca.880b   3.0   7.2(1)       8.3(0.156)RO Ok
  3  0026.0b7e.25a0 to 0026.0b7e.25cf  11.3   7.2(1)       8.3(0.156)RO Ok
  4  001b.54e7.ef60 to 001b.54e7.ef8f  11.1   7.2(1)       8.3(0.156)RO Ok
  5  000d.2910.2eec to 000d.2910.2eef   3.1   7.7(1)       12.2(18)SXD  Ok
  6  000d.bda4.0180 to 000d.bda4.0183   3.1   7.7(1)       12.2(18)SXD  Ok
  7  68ef.bd5e.89a0 to 68ef.bd5e.89cf  11.3   7.2(1)       8.3(0.156)RO Ok
  8  000f.f74b.9fda to 000f.f74b.a009  10.0   7.2(1)       8.3(0.156)RO Ok
  9  000d.ed72.c2a0 to 000d.ed72.c2cf   6.0   7.2(1)       8.3(0.156)RO Ok
Mod Sub-Module                  Model              Serial        Hw     Status
  5 Policy Feature Card 3       WS-F6K-PFC3A       SAD081005T1   2.2    Ok
  5 MSFC3 Daughterboard         WS-SUP720          SAD081007T2   2.2    Ok
  6 Policy Feature Card 3       WS-F6K-PFC3A       SAD081909J9   2.3    Ok
  6 MSFC3 Daughterboard         WS-SUP720          SAD082009YZ   2.2    Ok
Mod Online Diag Status
  1 Pass
  2 Pass
  3 Pass
  4 Pass
  5 Pass
  6 Pass
  7 Pass
  8 Pass
  9 Pass
CH-6509#
CH-6509#show ver
IOS (tm) s72033_rp Software (s72033_rp-JK9S-M), Version 12.2(18)SXD, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 29-Jul-04 00:26 by cmong
Image text-base: 0x4002100C, data-base: 0x42698000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9S-M), Version 12.2(18)SXD, RELEASE SOFTWARE (fc2)
CH-6509 uptime is 1 year, 50 weeks, 2 days, 17 minutes
Time since CH-6509 switched to active is 35 weeks, 21 hours, 12 minutes
System returned to ROM by Stateful Switchover (SP by power-on)
System restarted at 15:46:48 Aust_WA Fri Oct 30 2009
System image file is "sup-bootflash:s72033-jk9s-mz.122-18.SXD.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 3.0) with 458720K/65536K bytes of memory.
Processor board ID TBP06290039
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
29 Virtual Ethernet/IEEE 802.3  interface(s)
268 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You're thinking a 6708?
Since you're running 12.2(18)SXD, you might want to check release notes and see if the card is supported on that version of an IOS.  If not, you'll need to upgrade to a newer IOS.
Other than that, since your chassis is fully loaded, you might also check you'll have enough power.  However, since you'll need to swap a card, it's likely you'll have enough power, but still worth double checking.
