Cisco 6509 and Cisco 6503 hardware compatibility
UniWAQ
Hello Community
We are using Cisco 6509-E and wants to replace with Cisco 6503-E . The Cisco 6509  has  following inventory:-
#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6848-GE-TX     SSSS3
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G       SSSSSS
  8   48  CEF720 48 port 1000mb SFP              WS-X6848-SFP       YYYY
  9   20  DCEF2T 4 port 40GE / 16 port 10GE      WS-X6904-40G      YYYY
#show power
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       5771.64 137.42 OK     OK     on
2    WS-CAC-6000W       5771.64 137.42 OK     OK     on
My question is that could we use the same power supply on Cisco 6503-E chasis. I think so  we could not use this power supply but other line cards are compatible with Cisco 6503 with VS-SUP2T-10G.
Welcome for further comments for module compatibilty for 6503 .
Leo Laohoo
Won't fit.
6503 = 3 slots & there are 4 line cards.
Mark Malone
Your line cards are supported definitely as per doc
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-6500-series-supervisor-engine-2t/data_sheet_c78-648214.html#
May have an issue with the PS heres a full guide to all power supplys supported on which chassis , show you exactly what you can get with 6503
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/6500_ins/0apwsply.html#pgfId-1026788
Note Because of form-factor differences, the 6000 W AC-input and the 6000 W DC-input power supplies cannot be installed in the Catalyst 6503, Catalyst 6503-E, and Catalyst 6504-E switch chassis.
