Cisco 6509 VSS IOS Upgrade (ISSU eFSU and changing featureset?)
Simon Bonham
Hi all,
I am going to be upgrading a set of Cat 6500’s with Sup 720’s from the following version of software. Notice it is also a change of featureset. And according to the upgrade notes, the eFSU will fail its compatibility check when doing the upgrade… So does this mean I cant do an ISSU or is it just a warning and  I can do a workaround?
Fourth Bullet point:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/issu_efsu.html#wp1116940
From Versjon:        Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI11, RELEASE SOFTWARE (fc2)
To Versjon:         Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI13, RELEASE SOFTWARE (fc3)
So anyone have experience on this?
julijime
Hi Simon,
Unfortunately that is not a warning only, the eFSU between different featureset will fail and as an option you would need to schedule a downtime and reload the whole VSS in order to make that change.
Julio
