Cisco 6509 with Reliability 255/255, txload 238/255, rxload 8/255 interface
aporcaro01
Hi there,
   I'm having an issue with my Cisco 6509. One of Internet configured as trunk Interface direct with a HP7500 is showing reliability 255/255, txload 238/255, rxload 8/255.
   The Issue is that my Cacti Server show me that only 10% of the link is in use but if you look at txload you can see that almost 100% of the bandwidth is in use..
  What can I do in order to figure out what's going on with this Interface.  I'm thing about to put wireshark and configure a port monitor in order to capture the packets.
Is anyone has any tip to do a troubleshoot with this issue??
SWITCH01#show int port-channel 10
Port-channel10 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is c47d.4fbf.a8c2 (bia c47d.4fbf.a8c2)
  Description: CORECISCO_X_COREHP
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi8/19 Gi8/20
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 1w0d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 66043000 bits/sec, 23041 packets/sec
  5 minute output rate 1871148000 bits/sec, 186439 packets/sec
     15127300343 packets input, 6121405739799 bytes, 0 no buffer
     Received 232321316 broadcasts (161670914 multicast)
     0 watchdog, 0 multicast, 0 pause input
     118621325538 packets output, 141124879219641 bytes, 0 underruns
SWITCH01#
Adriano
5 Replies 5
Leo Laohoo
You may want to initially want to use netflow so you'll be able to know what's causing the high load on this etherchannel.
Thank Leo
  I´m gonna try to use netflow,
 Adriano
glen.grant
  This pretty much tells you your port channel is pretty full.  How many ports in the channel?
Output shows Gi 8/19 and Gi 8/20 the only members in the port channels that are active.
Hi,  there are two ports... gi8/19 and gig8/20.
