CISCO 6509E switch configuration
tejasAtluri
Following is the config output of CIsco 6509E chasis.
> NOLACORE#sh int te1/6/16
> TenGigabitEthernet1/6/16 is up, line protocol is up (connected)
>   Hardware is C6k 10000Mb 802.3, address is f866.f220.5027 (bia f866.f220.5027)
>   Description: BKUP:SSCPRODENG-NXGE4
>   MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
>      reliability 255/255, txload 1/255, rxload 1/255
>   Encapsulation ARPA, loopback not set
>   Keepalive set (10 sec)
>   Full-duplex, 10Gb/s, media type is 10Gbase-LRM
>   input flow-control is on, output flow-control is off
>   ARP type: ARPA, ARP Timeout 04:00:00
>   Last input never, output 00:00:19, output hang never
>   Last clearing of "show interface" counters 7w4d
>   Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
>   Queueing strategy: fifo
>   Output queue: 0/40 (size/max)
>   5 minute input rate 0 bits/sec, 0 packets/sec
>   5 minute output rate 81000 bits/sec, 7 packets/sec
From the output , we can see thatthe speed ste is 10G.
But it is forced or autonegotitated? Which parameter gives that information?
jimmysands73_2
Level 5
Level 5
Its a fiber line.
http://en.wikipedia.org/wiki/10_Gigabit_Ethernet
http://www.networkworld.com/community/node/27511
grinch182
sh run interface [interface number] - will show you if speed is hard coded.
Sincerely,
GRinch
Leo Laohoo
It's forced.  You can't neogotiate the speed and/or the duplex to anything else.  The parameters are the modules you are using.  You are using "10Gbase-LRM" then the link will negotiate to 10Gb, Full duplex and nothing less.
tejasAtluri
Thanks everybody..
That was really helpful.
We are running into interop issue between SPARC 10G XAUI and  CISCO 6509,10G base LRM.
So we were suspecting the negotiation, if anything exists like the one in copper channels
