Cisco 6807 - Critical firmware upgrade available for Module: 2
Adam Ayoub
Hello folks, hope you're all doing well. First time working with these switches, and I've encountered several hurdles that I was able to solve until this. I get the following error message after upgrading to ios Version 15.5(1)SY8.
************************ !! UPDATE REQUIRED !! ************************
Critical firmware upgrade available for Module: 2.
Please refer Software release documentation for more information.
I ran the following commands rebooted each time:
upgrade winters-flash slot 2 bundled-image
hw-module module 2 reset
It unfortunately did not remove the warning. Any ideas or tips please?
Thanks in advance,
Adam
2 Accepted Solutions
balaji.bandi
May be you are hitting with the BUG :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv17566
BB
Leo Laohoo
I know exactly what this is.  Someone may want to sit down because the story can make your toes curl and stomach hurl. So here goes ...
WARNING
DO NOT USE ISSU or FSU/eFSU if upgrading to 15.5(1)SY train on a 6807/6880 chassis.
IMPORTANT:  Read the Release Notes very, very carefully.
Pay very, very close attention to the "Performing FPGA Upgrade" section.  There are three things everyone must be aware warned of:
1. You will need console access or line cards will not boot.;
2.  For unknown reason, the line cards needs to have an FPGA upgrade done MANUALLY.  This can only be done once the new IOS gets loaded.  This FPGA upgrade is not "incorporated" in the IOS.
3.  The command to do the FPGA upgrade is a "bug".  For VSS, the command is:
upgrade winters-flash switch switch-number slot <slot-number> bundled-image GOLD
For stand-alone, the command is:
upgrade winters-flash slot <slot-number> bundled-image GOLD
See the last option, "GOLD"?  That option is HIDDEN and the fact that it is a hidden option is not documented anywhere else.
Once the reboot is complete, there will be some line cards that will "refuse" to boot up.  If a console cable is attached before rebooting the chassis there will be a "large" message stating that FPGA upgrade must be done, however, the command to do the FPGA upgrade is not mentioned.  The time it will take, after the panic has wane, to find the flippin' FPGA upgrade command will obviously run into an hour or two.
5 Replies 5
balaji.bandi
BB
This got rid of the warning. Thank you!
Thanks to everyone else who responded as well.
Reza Sharifi
Is the module actually working? What is the output of "show module"?
marce1000
              - And perhaps also : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv17552
 M,
Leo Laohoo
WARNING
