ERSPAN Question
twill0097
The command
monitor erspan origin ip-address x.x.x.x global is not working on a cisco nexus 7700 firmware 8.3.
Has anyone had an issue like this and what did you do to resolve the issue?
balaji.bandi
Can you post more information here :
show monitor session {all | session-number | range session-range} [brief]
You can configure an ERSPAN session on the local device only. By default, ERSPAN sessions are created in the shut state.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide-RI/configuring_erspan.html#concept_B33B4BA171834C8D81D288E388B5091F
BB
ashishr
Hi @twill0097
Can you elaborate the problem? Is the CLI not working or the configuration is not taking affect.
If the CLI is not working try reconfiguring step-by-step.
https://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/113480-erspan-nexus-7k-00.html
Here is an example from the guide-
!--- Configures an ERSPAN source session.
switch_1(config)#monitor session 48 type erspan-source
!--- Configure the sources and traffic direction.
switch_1(config-erspan-src)#source interface Ethernet2/10 both
!--- Configure the destination IP address in the ERSPAN session.
switch_1(config-erspan-src)#destination ip 10.11.11.3
!--- Configure the ERSPAN ID.
switch_1(config-erspan-src)#erspan-id 902
!--- Configure the VRF.
switch_1(config-erspan-src)#vrf default
!--- Enable the ERSPAN source session (by default the session is !--- in shutdown state).
switch_1(config-erspan-src)#no shut
switch_1(config-erspan-src)#exit
!--- Configure the ERSPAN global origin IP address.
switch_1(config)#monitor erspan origin ip-address 10.254.254.21 global
Ashish
