Cisco 6807 SUP6T Switch - Receiving USBFLASH errors
Quintin.Mayo
Level 3
Level 3
We have a 6807 SUP6T switch with two supervisor units installed, after upgrading and rebooting the device we are now receiving the below USBFLASH errors. Based on the logs the issue seem to be related to the usb flash drive. When we went to re-seat the supervisor module we noticed there are no USB flash drive in/on the unit. So, we are not sure why we are now receiving the errors or where to find the USB Flash drive.  Any assistance would be greatly appreciated.
*Nov 29 14:53:28.183: %USBFLASH-3-RDERROR: Failures in usbflash sector read, sect = 7498758, nsect = 8, device = bootdisk -Traceback= 23EFCF9z 5389D46z 59083EDz 59067E8z 590E60Fz 590E3ECz 5905A0Ez 59043D9z 5903DB5z 58F4AA1z 5907247z 538679Fz 287E215z 552CA35z 5528AFCz
*Nov 29 14:53:28.283: %USBFLASH-3-WRERROR: Failures in usbflash sector write, sect = 7497902, nsect = 1, device = bootdisk -Traceback= 23EFCF9z 5389F06z 590844Dz 59062B7z 590C172z 590BF40z 5906626z 58F3B09z 58F5931z 58F4A6Cz 5906FC1z 53864F2z 287DA3Az 552CA43z 5528AFCz
balaji.bandi
6807 SUP6T have  Bootdisk :4 GB (eUSB)
You can raise an TAC case.  or you can run this command see if that fix the issue fsck bootdisk:
Technically should not impact, but do it in maintenance window.
BB
Leo Laohoo
Raise a TAC Case. That supervisor card's internal circuitry is having a problem.
The USBFLASH talks about the CF slot inside.
