07-11-2016 07:58 AM - edited 03-08-2019 06:34 AM
Could you tell me if there is a FWSM [ that is not nearing EOL ] that is would work with 6807 switch.
Is there such a module that included the Sourcefire Firepower services ?
Dal
Solved! Go to Solution.
07-11-2016 02:08 PM
None. FWSM will be the final line card to be supported in a 6500E/6807 chassis.
The reason behind this is the "real estate value" of the slots of the 6807.
07-11-2016 02:08 PM
