Cisco 6880X VSS SSO issue after failover
marc.groenen
We are implementing a Cisco C6880-X-LE VSS solution with multiple C6800IA-48TD connected to it.
Currently we are running c6880x-ipservicesk9-mz.SPA.151-2.SY5.bin
We are currently still testing the configuration.
When we did a redundancy test a strange thing happened.
In datacenter A we have LaptopA connected to FEX-A in VLAN100 and in datacenter B we have LaptopB connected to FEX-B in vlan101.
Both the laptops can ping each other and also their GW's.
When we cut the power off the primary 6880 of the VSS cluster in datacenter A we can see that the clients lose 1 ICMP to their GW's and thats it which is great.
Now the 6880 in datacenter B is active while the 6880 in datacenter A is rebooting.
During this boot process after about 7 minutes the ping between the laptops breaks...
From the active 6880-B we can ping each laptop individually
Both the laptops can still ping their GW's, this stays for about 5 minutes then the laptop's can ping each other again.
At this time the 6880-A is fully rebooted  and the 6880-B is still active.
When we do the redundancy failover back to the 6880-A we do not see this issue.
We have done some bug searching and see some similarity's with the following bug:
https://tools.cisco.com/bugsearch/bug/CSCus93563
We are going to upgrade to c6880x-ipservicesk9-mz.SPA.152-1.SY1.bin today and see if this goes better.
marc.groenen
After the upgrade to c6880x-ipservicesk9-mz.SPA.152-1.SY1.bin  the failover test is OK no more unexpected connectivity loss.
Maybe it still had something to do with CSCus93563
