cisco 7200 NPEG2 bootloader issue and low performance
Dr.X
Level 2
Level 2
i have 2 cisco 7200 identical routers and work the same work as LNS and same load
but i found that CPU on Router 1 is higher 10 % than cpu on Router 2
i did alot of investigation but no luck
finally i foud something different in the IOS and boot laoder version .
i will post config of the  good router performance then the config of  higher cpu router .
1- good router performance :
Bras2#sh ver
Bras2#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 09-Sep-12 07:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(4)XD, RELEASE SOFTWARE (fc1)
Bras2 uptime is 15 weeks, 8 hours, 28 minutes
System image file is "disk2:c7200p-adventerprisek9-mz.124-24.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 26790100
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.9
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Bras2#sh ve
Bras2#sh version
Bras2 uptime is 15 weeks, 8 hours, 30 minutes
export@cisco.com.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
254464K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Bras2# sh bootv
Bras2# sh bootvar
BOOT variable = disk2:c7200p-adventerprisek9-mz.124-24.T8.bin,1;disk2:c7200p-adventerprisek9-mz.124-24.T7.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
WARM_REBOOT variable = FALSE
Bras2# sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        31E6C0CD  80D9F8   28  7919992 Apr 27 2011 10:32:31 +03:00 c7200p-kboot-mz.124-4.XD.bin
2   .. config       AF4F98C5  80F580   16     6917 Mar 6 2001 15:49:06 +03:00 ns-gateway-confg
3   .D image        D9C0D081  F9E9F4   37  7926772 Mar 6 2001 16:13:48 +03:00 c7200p-kboot-mz.124-4.XD5-Gateway.bin
4   .D image        D9C0D081 172DE68   37  7926772 Mar 6 2001 18:00:13 +03:00 c7200p-kboot-mz.124-4.XD5-Gateway.bin
5   .D image        D9C0D081 1EBD2DC   29  7926772 Mar 6 2001 18:05:14 +03:00 c7200p-kboot-mz.124-4.XD5.bin
6   .. config       D7477BA9 1EBEBF4    9     6294 Mar 7 2001 17:44:54 +03:00 newconfig
7   .. config       5719EC7F 1EC08A4    4     7214 Mar 24 2001 15:57:00 +03:00 xp10
33814364 bytes available (31721636 bytes used)
Bras2#
Router 2 that has higer CPU .
BRAS3#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T7, RELEASE SOFTWARE (fc2)
Compiled Tue 28-Feb-12 12:53 by prod_rel_team
BRAS3 uptime is 19 weeks, 1 hour, 2 minutes
System image file is "disk2:/c7200p-adventerprisek9-mz.124-24.T7.bin"
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID 13252317
6 slot VXR midplane, Version 2.0
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
BRAS3# sh fl
BRAS3# sh bo
BRAS3# sh bootv
BRAS3# sh bootvar
BOOT variable = disk2:/c7200p-adventerprisek9-mz.124-24.T7.bin,1;
BRAS3# sh bootfl
BRAS3# sh bootflash:
1   .. image        D9C0D081  80F474   29  7926772 Sep 15 2000 09:01:42 +02:00 c7200p-kboot-mz.124-4.XD5.bin
2   .. config       FAC0ADBE  81113C   21     7240 Dec 23 1999 01:25:25 +02:00 gateway-runn16/7/2012
3   .. config       FAC0ADBE  812E04   15     7240 Dec 24 1999 07:34:43 +02:00 1772012configgg
4   .. config       C3708676  814B00    7     7290 Dec 25 1999 07:05:55 +02:00 1872012
57586944 bytes available (7949056 bytes used)
BRAS3#
i have 2 notes :
1- in router with  high cpu i cant see the boot loader in the commad (show version)
2- router with high cpu i cant see many files in the command (show bootflash)
i feel that this issue is doing Higer CPU .
here is CPU comparision :
Bras2#sh processes cpu sorted
CPU utilization for five seconds: 65%/59%; one minute: 66%; five minutes: 65%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  87   755920508   582337149       1298  3.11%  2.70%  2.37%   0 IP Input
 122   264201920   168945594       1563  1.35%  1.15%  1.02%   0 L2X Data Daemon
 270    17304100   300521128         57  0.63%  0.64%  0.63%   0 PPP Events
 112    40540376    14043032       2886  0.31%  0.31%  0.31%   0 CEF: IPv4 proces
 142     1148560  2232207423          0  0.23%  0.23%  0.23%   0 HQF Shaper Backg
  52    39616916     1825158      21706  0.23%  0.22%  0.23%   0 Compute load avg
  78     1107068    16023819         69  0.15%  0.12%  0.13%   0 ACCT Periodic Pr
 258    22339980    65329658        341  0.15%  0.10%  0.10%   0 RADIUS
BRAS3#sh processes cpu sorted
CPU utilization for five seconds: 76%/67%; one minute: 75%; five minutes: 75%
  87   843463936  1240374360        680  3.75%  4.12%  4.04%   0 IP Input
 122   287951140   668143305        430  1.51%  1.62%  1.60%   0 L2X Data Daemon
 263    20626476   376044742         54  0.63%  0.66%  0.64%   0 PPP Events
 269    90045028   128764669        699  0.39%  0.41%  0.40%   0 SNMP ENGINE
 112    44340784    17702557       2504  0.31%  0.32%  0.31%   0 CEF: IPv4 proces
 142     1502348  2800696191          0  0.23%  0.23%  0.23%   0 HQF Shaper Backg
 274    21678800     3831880       5657  0.23%  0.13%  0.09%   0 VTEMPLATE Backgr
  52    43958228     2302505      19091  0.23%  0.23%  0.23%   0 Compute load avg
 267    34037648   250332320        135  0.15%  0.13%  0.15%   0 IP SNMP
 258    24378236    75734571        321  0.15%  0.12%  0.10%   0 RADIUS
  96     1402556   125702660         11  0.15%  0.14%  0.15%   0 IPHC Admin
hope to help .
cheers
acampbell
You seem to have high "IP INPUT" processing
Start your investigation by looking at this link
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41160-highcpu-ip-input.html
Alex
Regards, Alex. Please rate useful posts.
thsi vlaue is natural
but im asking here
whey a router with same traffic have more 10 %
im sure its not config and i guess its an Ios issue
that's why i  asked here about the IOS
i dont see bootloader version , could this affect the ios behavior ?
