How to display Transceiver Cisco PID in Nexus platform?
BenBen
'show inventory' can display Cisco part number (PID) in IOS.
'show interface transceiver' command in NX-OS only shows the technical specification but not the Cisco Part Number (PID). Any body know what NX-OS command can show the PID of transceivers?
Ethernet1/11
    transceiver is present
    type is SFP-1000BASE-T
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4
    revision is B2
    serial number is AGM182xxxxx
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
Thanks.
Bilal Nawaz
Hello Frank, may I ask why you need the PID?
The part number is displayed as ABCU-5710RZ-CS4.
If the SFP is not working on your Nexus, please try setting the speed to 1000mb by inputting the command "speed 1000" and "duplex full" under interface e1/11.
You may have to pull out the SFP and insert it back in.
Hope this helps.
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thank you Bilal.
It may not technically requires the PID. It can help the customer to order new SFPs with Cisco PID. But it makes the customer feels uncomfortable to have a genuine SFP shown as PID 'unspecified'. It is a cosmetic defect at least. Cosmetice defect is stil a defect.
The reason may not strong but it is valid I think.
Thanks.
Do you see something like this?
 sh interface <> transceiver details
    type is 10Gbase-SR
    name is CISCO-AVAGO
    part number is SFBR-7700SDZ-CS2
    revision is B5
    serial number is AGD131231HB
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 62.5/125um fiber is 26 m
    Link length supported for 50/125um OM3 fiber is 300 m
    cisco id is --
    cisco part number is 10-2415-02
    cisco product id is SFP-10G-SR
    cisco vendor id is V02
I believe that display (including Product ID) is only available on NX OS 6.1 or 6.2 and greater.
