Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 7k acl and hit count....
mbaars
Hi All,
Seeing a strange access-list hitcount issue on Nexxus 7k running 7.3(5).
Within an access-list there are some acl entries not showing any matches. For an acl entry without matches it would say '[match=0]' but for some lines this is omitted. Any ideas? Is there some logging restriction on the maximum of acl entries or a bug that i should be aware of? We have a lot of acl's on this Nexxus 7k that need to be analysed and unused entries removed.
Example
N7K-01# sh access-list vlan22-in
IP access list vlan99-in
statistics per-entry
<omitted>
1700 permit ip 10.101.22.0/24 10.101.5.0/24 [match=300150756]
1710 permit ip 10.101.22.0/25 10.247.0.0/16 [match=0]
1720 permit ip 10.101.22.22/32 52.239.137.36/32 <<<<<< no match/hitcounter
1730 permit ip 10.101.22.105/32 10.101.3.0/24 <<<<<< no match/hitcounter
1740 permit ip 10.101.22.0/25 10.111.96.0/24 <<<<<< no match/hitcounter
1750 permit ip 10.101.22.0/25 10.111.97.0/24 <<<<<< no match/hitcounter
6 Replies 6
balaji.bandi
Do you have any traffic that matches the ACL?
BB
Good question
I am assuming there is matching traffic.
But even so, without matching traffic i would expect '[match=0]' to be included when viewing the acl?
I am assuming there is matching traffic.  - need confirmation or create another ACL you known device and test it.
BB
statistics <<- add this command under the ACL again, and share the result
I removed ' statistics per-entry' under the acl and added it again but the result is still the same....
I check the ciscolive slides
the PACL with statistics per-entry show match for all line
the RACL with statistics per-entry show match only for traffic hit the line other line dont show match if there is no traffic hit the line
