Cisco 800 series router keeps freezing
NZSHoRtFuSe
Hi Guys
Hoping someone can help me with this, Have a remote Cisco 850 that keeps Freezing after a few weeks (customer has to turn it off and on again to get the internet up and running) Now i can't make it out there when it hangs so trying to work out want is wrong from afar .
The logs dont have anything leading upto the freezing.
Here is the config, Thanks!!!!
Using 5672 out of 131072 bytes
! No configuration change since last restart
! NVRAM config last updated at 11:53:47 PCTime Wed Apr 2 2014
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
logging buffered 64000
enable secret 5 xxxx
no aaa new-model
clock timezone PCTime 12
clock summer-time PCTime date Mar 16 2003 3:00 Oct 5 2003 2:00
crypto pki trustpoint TP-self-signed-2561631828
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2561631828
 revocation-check none
 rsakeypair TP-self-signed-2561631828
crypto pki certificate chain TP-self-signed-2561631828
 certificate self-signed 01 nvram:IOS-Self-Sig#C.cer
dot11 syslog
ip cef
ip inspect name CCP_LOW cuseeme
ip inspect name CCP_LOW dns
ip inspect name CCP_LOW ftp
ip inspect name CCP_LOW h323
ip inspect name CCP_LOW sip
ip inspect name CCP_LOW https
ip inspect name CCP_LOW icmp
ip inspect name CCP_LOW imap
ip inspect name CCP_LOW pop3
ip inspect name CCP_LOW rcmd
ip inspect name CCP_LOW realaudio
ip inspect name CCP_LOW rtsp
ip inspect name CCP_LOW esmtp
ip inspect name CCP_LOW sqlnet
ip inspect name CCP_LOW streamworks
ip inspect name CCP_LOW tftp
ip inspect name CCP_LOW tcp
ip inspect name CCP_LOW udp
ip inspect name CCP_LOW vdolive
login block-for 60 attempts 3 within 60
login on-failure log
login on-success log
username xxxx
username xxx
archive
 log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description $FW_OUTSIDE$
 ip address 2xx.xx.x.xx 255.255.255.254
 ip access-group 102 in
 ip verify unicast reverse-path
 ip inspect CCP_LOW out
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Vlan1
 description $FW_INSIDE$
 ip address 192.168.3.250 255.255.255.0
 ip access-group 100 in
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 210.55.3.78
ip route 192.168.4.0 255.255.255.0 192.168.3.253
ip route 192.168.5.0 255.255.255.0 192.168.3.253
ip route 192.168.201.0 255.255.255.0 192.168.3.253
ip http server
ip http authentication local
ip http secure-server
ip http secure-port 4443
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.3.5 25 interface FastEthernet4 25
ip nat inside source static tcp 192.168.3.5 443 interface FastEthernet4 443
ip nat inside source static tcp 192.168.3.5 80 interface FastEthernet4 80
ip nat inside source static tcp 192.168.3.5 4125 interface FastEthernet4 4125
ip nat inside source static tcp 192.168.3.4 53389 interface FastEthernet4 53389
ip nat inside source static tcp 192.168.3.5 3389 interface FastEthernet4 43389
logging trap debugging
logging 192.168.3.5
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 192.168.201.0 0.0.0.255
access-list 100 remark auto generated by CCP firewall configuration
access-list 100 remark CCP_ACL Category=1
access-list 100 deny   ip xxx.xxx.xxx 0.0.0.1 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 102 remark auto generated by CCP firewall configuration
access-list 102 remark CCP_ACL Category=1
access-list 102 remark Auto generated by SDM for NTP (123) 1.nz.pool.ntp.org
access-list 102 permit udp host xxx.xxx.xxx eq ntp host xxx.xxx.xxx eq ntp
access-list 102 permit tcp any host xxx.xxx.xxx eq 43389
access-list 102 permit tcp any host xxx.xxx.xxx eq 53389
access-list 102 permit tcp any host xxx.xxx.xxx eq 4125
access-list 102 permit tcp any host xxx.xxx.xxx eq www
access-list 102 permit tcp any host xxx.xxx.xxx eq 443
access-list 102 permit tcp any host xxx.xxx.xxx eq smtp
access-list 102 deny   ip 192.168.3.0 0.0.0.255 any
access-list 102 permit icmp any host xxx.xxx.xxx echo-reply
access-list 102 permit icmp any host xxx.xxx.xxx time-exceeded
access-list 102 permit icmp any host xxx.xxx.xxx unreachable
access-list 102 permit tcp host xxx.xxx.xxx host xxx.xxx.xxx eq 4443
access-list 102 permit tcp host xxx.xxx.xxx host xxx.xxx.xxx eq 22
access-list 102 permit tcp host xxx.xxx.xxx host xxx.xxx.xxx eq cmd
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip host 0.0.0.0 any
access-list 102 deny   ip any any log
control-plane
banner motd ^C
* Unauthorized access prohibited
^C
line con 0
 no modem enable
line aux 0
line vty 0 4
 login local
scheduler max-task-time 5000
sntp server xxx.xxx.xxx
end
5 Replies 5
mohabdel
Hi Nzsh,
I think your config is ok, Also it is config by CCP so there is no error or mistake there.  However I think you did config DOS and sometime it shutdown routers Please delete the following command and test your customer router.
Moh
Thanks man.
will try it out and let you know how i go! :)
Hi. This is not a solution but only a workaround.
You can configure a scheduled reboot every night:
kron occurrence EVERY_DAY at 0:00 recurring
 policy-list RELOAD
kron policy-list RELOAD
 cli write
 cli reload
In this way you can analyze the problem without hurry.
BR
Do you have latest IOS?
BR
Ho Moh
So removed the below lines  like asked but still seem to need a restart every week or so, any other ideas?
Cheers!!
