cisco 805
ipothos1976
i have a cisco 805 and after a power failure router boots in TinyRom
what i have to do for a normal booting?
spremkumar
Level 9
Level 9
hi
can you try configuring boot system flash:iocode.bin (ioscode.bin available ios file in your flash) ?
regds
in the ,#boot, level when i type "boot", router boots normally...but when i am trying to reboot it i have the same result, i mean router boots in TinyRom again.
Once you issue boot statement on the #boot prompt and get onto your normal router prompt try configuring the command which i have mentioned in my earlier post.
After that save the config and do a reload it should boot properly.
regds
