Cisco 8200L-1N-4T
Hayat Zarin
Hello everyone one I have cisco 8200L router I want to upload ios from USB ( 8gb 2.0) the following error is showing.
media drive (usbflash0:) failed. error code: 0x2
When I try to upload through tftp the following error is showing.
monitor: command "tftpdnld" not found.
what is issue.
@Cisco Support
7 Replies 7
@Hayat Zarin
 Take a look on this table where cisco mention USB 3.0
https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8300/software_config/cat8300swcfg-xe-17-book/isr9000swcfg-xe-16-12-book_chapter_0111.html
File Systems
The following table provides a list of file systems that can be seen on the Cisco Catalyst 8000 Series Edge Platform.
Table 1. Device File Systems
File System
Description
bootflash:
Boot flash memory file system.
flash:
Alias to the boot flash memory file system above.
harddisk:
Hard disk file system (NVME-M2-600G or USB-M2-16G or USB-M2-32G with the CLI command harddisk).
cns:
Cisco Networking Services file directory.
nvram:
Device NVRAM. You can copy the startup configuration to NVRAM or from NVRAM.
obfl:
File system for Onboard Failure Logging (OBFL) files.
system:
System memory file system, which includes the running configuration.
tar:
Archive file system.
tmpsys:
Temporary system files file system.
usb0: USB 3.0 Type- A
usb1: USB 3.0 Type-B
The Universal Serial Bus (USB) flash drive file systems.
Note
The USB flash drive file system is visible only if a USB drive is installed in usb0: or usb1: ports.
@Flavio Miranda sir USB 3.0 also tried but same error showing
Make sure you formated It in FAT and use 4giga  pendriver
Leo Laohoo
Translation:  The USB flash drive used is not compatible.
Find a different variety.  I use brands like Toshiba or Lexar.
@Leo Laohoo sir Toshiba or lexar means can you explain
Hello @Hayat Zarin ,
please make sure your usb drive is formatted FAT32.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
@liviu.gheorghe sir USB formated with FAT 32
