Cisco 841M-4X
navneet.k
Need to know what will be the forwarding capacity in Kpps of Cisco841M-4X router at 64 bytes. Also if any public document available, pls share the link
Navneet
I wouldn't go by that until you get something on paper that backs it up , it could support more as its new , 890 has been around a while
Mark Malone
Heres the data sheet for the device , no specific spec on throughput ,dont see it listed on the other docs either yet with the other 800 series estimated throughput speeds
https://www.cisco.com/c/en/us/products/collateral/routers/800m-integrated-services-router-isr/datasheet-c78-732678.html
http://www.anticisco.ru/pubs/ISR_G2_Perfomance.pdf
As per the performance guide, 890 support 100 kpps of forwarding rate at 64 bytes so it means 840M will support 100kpps or less forwarding rate at 64 bytes.
I hope my understanding is corrrect.
