cisco switch 3850
selim
when i rty to configure ospf  on cisco switch 3850  "protocol not in this image"
What would be ths solution
Seb Rupik
Hi there,
You need a minimum of an IP Base license for OSPF.
What is the output of sh license ?
cheers,
Seb.
Joseph W. Doherty
Insure the 3850 is loaded/licensed to support OSPF.
GRANT3779
This will be related to the feature set you are running on the switch -
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
Table 2.
If you run the following command on your switch to see what you currently have -
#show license right-to-use
Slot# License name Type Count Period left
1 ipservices permanent N/A Lifetime
1 ipbase permanent N/A Lifetime
License Level on Reboot: ipservices
2 ipservices permanent N/A Lifetime
Mark Malone
This will allow you ospf for 90 days under eval license until you buy it
license right-to-use activate ipservices evaluation
