09-21-2007 05:53 PM - edited 03-05-2019 06:38 PM
Good morning,
Can anyone advise on the configuration of a DMZ in the above router? I am looking for some sample configurations or general pointers on configurating the DMZ for the 857W router.
Thanks for your help
Craig
09-23-2007 08:06 PM
hi
i dont think you will be able to create dmz with our cisco 857w router as you can do with cisco 870 series routers.
you can refer the below link for more info on the capabilities of the box..
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a9a9.html
regds
Log in to Community
