[Cisco 861] AccessList not working
ArendvanDijk
In a test environment (before going to the production environment) I've installed a router with 2 VLAN's.
VLAN 1 is for the customer and VLAN 2 is for the suppliers of the customer.
I want so that VLAN 2 shouldn't be able to access any device in VLAN 1 (excluding traffing to a specific IP-adres (200.200.200.61))  but VLAN 1 should be able to access all devices in VLAN 1 & 2.
VLAN 1 200.200.200.x/24
VLAN 2 200.200.201.x/24
ACL:
access-list 140 permit ip 200.200.201.0 0.0.0.255 200.200.200.61 255.255.255.255
access-list 140 deny ip 200.200.201.0 0.0.0.255 200.200.200.0 0.0.0.255
access-list 140 permit ip 200.200.201.0 0.0.0.255 any
access-list 150 permit ip 200.200.200.0 0.0.0.255 200.200.201.0 0.0.0.255
access-list 150 permit ip 200.200.200.0 0.0.0.255 any
interface Vlan1
ip address 200.200.200.1 255.255.255.0
ip access-group 140 in
interface Vlan2
ip address 200.200.201.1 255.255.255.0
ip access-group 150 in
With this access lists there is no traffic possible.
Can some one tell me how these  access list should look likes?
Arend
John Blakley
Arend,
I think your acl needs a little tweaking:
ACL:
Change to:
access-list 150 permit ip 200.200.200.0 0.0.0.255 host 200.200.200.61
access-list 150 deny ip 200.200.201.0 0.0.0.255 200.200.200.0 0.0.0.255
access-list 150 permi ip any any
interface Vlan1
interface Vlan2
HTH,
John
HTH, John *** Please rate all useful posts ***
8 Replies 8
Abzal
Level 7
Level 7
First of all looking to your config you need fix something
interface Vlan1
interface Vlan2
And you don't need apply any ACL for  VLAN 1 for such purpose. Because by default it will allow all traffic and you have onlt two VLAN unless specific restrictions.
But in this case traffic that goes VLAN 1 --> VLAN 2 but answer VLAN 2 --> VLAN 1 is blocked. It won't work. You can check with ping it. Request will go but answer won't pass ACL on VLAN 2.
Hope it will help.
Best regards,
Abzal
Thank you for your fast reply. I've adjusted the settings, but unfortunately it does not work.
First I get no IP-adress. By configuring the IP-address manually I haven't access to the Cisco (telnet and ping are blocked).
Any suggestions?
Thanks a lot!
Arend
Can you show your network topology to better undestand. Ping for devices on the same VLAN 1 should be ok. But ping from VLAN 2 --> VLAN 1 and VLAN 1 --> VLAN 2 are blocked by ACL. But within VLAN 2 ping should be ok as well.
Pos your config.
Hope it will help.
Best regards,
Abzal
The network topology is very simple. The Cisco router had 4 LAN-ports. FA0 and FA1 are VLAN 1, the other two VLAN 2.
### See config ###
version 15.2
no service pad
service password-encryption
service sequence-numbers
hostname XXX-rt01
boot-start-marker
boot-end-marker
logging buffered 51200
enable secret XXX
no aaa new-model
memory-size iomem 10
clock timezone CET 1 0
clock summer-time SUM recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip bootp server
ip name-server 192.168.210.1
ip cef
username XXX password XXX
ip dhcp excluded-address 200.200.200.1 200.200.200.10
ip dhcp excluded-address 200.200.200.61
ip dhcp excluded-address 200.200.201.1 200.200.201.10
ip dhcp pool XXX-network
network 200.200.200.0 255.255.255.0
dns-server 200.200.200.1
default-router 200.200.200.1
lease 5
ip dhcp pool suppliers-network
network 200.200.201.0 255.255.255.0
dns-server 200.200.201.1
default-router 200.200.201.1
lease 5
interface FastEthernet0
description LAN-port XXX-network
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
description LAN-port suppliers
switchport access vlan 3
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description Internetpoort
ip address 192.168.210.100 255.255.255.0
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
interface Vlan1
description XXX-network
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Vlan3
description suppliers-network
ip nat inside
no autostate
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.210.1
ip nat inside source list 101 interface FastEthernet4 overload
access-list 23 remark Telnet
access-list 23 permit 200.200.200.0 0.0.0.255
access-list 23 permit 200.200.201.0 0.0.0.255
access-list 101 remark NAT
access-list 101 permit ip 200.200.200.0 0.0.0.255 any
access-list 101 permit ip 200.200.201.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
snmp-server community cit RO
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Config looks ok for me. When you configure IP manually subnet mask and gateway are correct?
Anyway DHCP should work. Telnet access as well.
Best regards,
Abzal
John Blakley
Arend,
ACL:
Change to:
interface Vlan1
interface Vlan2
HTH,
John
Hi John,
Thanks a lot! It's working!
Final config:
access-list 150 permit ip 200.200.201.0 0.0.0.255 host 200.200.200.61
access-list 150 permit ip any any
interface Vlan1
interface Vlan2
Glad to hear it!
